-   -   1 piece driveline (https://67-72chevytrucks.com/vboard/showthread.php?t=84957)
66nova383 01-11-2004 12:45 PM
1 piece driveline
I am working on a 69 swb 2wd with coil rear,if I switch to a 1 piece driveline will I need to cut the hole in the crossmember larger?
FuelCellGuy 01-11-2004 12:50 PM
No....
you should however, remove the carrier bearing bracket.
Longhorn Man 01-11-2004 01:33 PM
And if you have a TH350 with the short shaft tail on it, then 4 foot and 10 inches should be what you need.
Just noticed you are a new member...welcome to the board from frigid central Ohio.
Rod 01-11-2004 01:45 PM
Welcome to the 67-72Chevy boards.
FRENCHBLUE72 01-11-2004 02:15 PM
Welcome to the board !!!!! Andy it thet a custom built shaft or is it outta some production car??? Was wondering why it neck's down on the tail end before the joint???
1972C10 01-11-2004 03:37 PM
Alot of One peice driveshafts are like that
I run a th 350 Longtail and i use a driveshaft out of a 2 door chevelle
Longhorn Man 01-11-2004 04:05 PM
I had asumed it was original honestly...but with the miles this sucker has, there is no tellin.
I tell them I want U-joints for a 69 GMC and they give me the right ones.
lukecp 01-11-2004 04:07 PM
Welcome from Missouri :bowtie:
1972C10 01-11-2004 04:36 PM
If its a half ton You will want brand and part number PDQ-0153 that will get you somewhere most places sell Pdq brand stuff or have a book to cross it over as long as you get outside locks that will be the joint you will need If you want extreme Use U Joint Get a brute force p/n Bf-0153 now if you get a newer style driveshaft you will need inside locks In wich case i dont know the part numder but i can get it .
krue 01-11-2004 05:21 PM
Welcome to the board from South Mississippi!
