Diff-erent question
So I installed a new driveshaft and noticed that i’m guessing because of the 12 bolt pinion offset it is on a bit of an angle to the driver side and a little off center through hoop! I have squared up rearend in frame and measured perfect. Am I overthinking or is this normal? Sorry for crap pic,my phone sucks! Thanks
Re: Diff-erent question
Is the centreline of your motor parallel to the frame?
If not then your ds will look like that. I’ve seen motors offset an inch to the passenger side. |
I measured tail of transmission is dead centre
Maybe a bit better of a pic.
It's ok if the driveshaft goes off at an angle. The pinions are not always centered (you should see the offset on my 9" Ford!).
To get the pinion centered you would need different length axle shafts left and right, and manufacturers don't like the extra cost of doing that. |
Just what I wanted to hear lol.i can now move forward. Thanks
they should be offset some. keeps the universal joints from wearing
| All times are GMT -4. The time now is 07:47 AM. |
