Hello
Hi all, new member with 1971 C10/20.
I’ve been lurking for a while now - excellent information here! My newly purchased pickup is a C20 that’s been converted to a short bed. Based on what I’ve read here, that was done well. The truck doesn’t have much rust, all the most typical places are clean. Floorboards are in great shape, and as near as I can tell bed, fenders and hood are new metal. Runs well! It was advertised as a 383, but could be a 305-350. In time plan to install a mild 350. The transmission is a 700R4, which works, but will need some attention. Now the bad. Previous owner installed a Viper alarm with electric locks and windows. I plan to revert to stock. The wiring is in shambles with tons of poorly done connections ranging from wire taps, crimps, wire nuts etc. the battery was relocated under the bed…ah well I’m sure you guys get the idea. Working now to get basics working, electric fans were off due to a bad temp sending unit. Brake lights and headlights work but nothing else. Looking forward to getting the basics working with the existing wiring. In longer term, wiring harness replacement is top of the list. In any case very happy with purchase, plan to use it as a daily. |
Re: Hello
Welcome!! The truck looks good just by the way it looks on the trailer. We like pictures so if you do any work on the truck make sure you let us know what you did and include pictures. Or if you are needing help on something, provide pictures of what you're working on, and I am sure you will get a lot of responses. There is someone on this site who can answer any questions you have.
Re: Hello
:welcome2:
Welcome to the forum. Sounds like you got a Great deal, and you are aware of what needs to be done. There is a Sub-Forum just for your electrical that you probably are aware of in the link below. Link: https://67-72chevytrucks.com/vboard/...splay.php?f=64 The truck looks nice.:metal: |
| All times are GMT -4. The time now is 05:58 PM. |
