-   -   K10 disk brake caliper (https://67-72chevytrucks.com/vboard/showthread.php?t=858838)
pwdcougar 05-19-2025 08:07 PM
5 Attachment(s)
I picked up a 10 bolt corporate front axle assembly so I can put disk brakes on my 70 K10 Suburban. The seller said the axle was military surplus and has never been installed. I figured I'd post this in the square body section since it is probably from that generation. It still was bolted to the shipping blocks. One of the calipers is missing the plug over the brake line port so I want to replace it since the axle has been sitting outside for a while. Does anyone recognize this caliper? Online I've found similar calipers but none have the same configuration for the brake line. Any ideas wjat to search for?
Paul
v30crewcab 05-19-2025 09:37 PM
Re: K10 disk brake caliper
should just be an 84 k5 blazer caliper.
pwdcougar 05-19-2025 10:08 PM
I'm not familiar with the square body trucks. Is the 84 K5 Blazer caliper different from the other K series trucks?
72c20customcamper 05-20-2025 07:42 AM
Looks just like the calipers in my 85 k20
v30crewcab 05-20-2025 07:44 AM
not different, but most cucv blazers I've seen were 84 models.
kwmech 05-20-2025 11:08 AM
Best bet would be to change them as a pair or you may have issues down the road.
blakeduren 05-24-2025 02:11 PM
One thing to think about:
The 80's calipers would need a 10mm banjo bolt and matching brake line..
You might want to get dana 44 1970's calipers that take the 7/16 banjo bolt which would match a brake hose from a 71 or 72 disc brake truck.
