-   -   71 Chevy truck alternator bracket problem (https://67-72chevytrucks.com/vboard/showthread.php?t=858888)
prateroad 05-23-2025 11:53 AM
3 Attachment(s)
First off I've never had a problem with these brackets before. I thought mine was in a crash or something and i bought a used one off fleabay and it's the same alignment problem. pics tell the story. Thinking of putting a C50 bracket on but thinking belt will rub ps hose. It gets somewhat better when alternator is tightened but still out some. TIA
54blackhornet 05-23-2025 01:06 PM
Re: 71 Chevy truck alternator bracket problem
I have one off a 71 350 you can have for shipping..jack
weq92f 05-23-2025 01:18 PM
If this is the bracketry you've mounted, I can't see much if any user error that would cause the alt pulley to be so far off. Appears as though you've got it mounted correctly so all indications are that it's either the wrong bracket or it's bent up a bit. If you articulate the alt to where the top mounting ear is nearly straight up, does that change anything?
-Kevin
72c20customcamper 05-23-2025 04:00 PM
If Prateroad doesn’t want it I’m in need of one for my 72 it has a later model setup on it and I want to go back to original
1970cstblazer 05-24-2025 07:16 AM
Common mistake for these brackets is for the upper bracket to be mounted on the wrong side of the upper alternator mounting ear. Seen it here a lot even by the top restorers.
70STOVEBOLT 05-24-2025 09:32 AM
The alternator pulley looks incorrect to me
Steeveedee 05-24-2025 12:27 PM
I think you're right. Shouldn't the pulley be right at the fan, not spaced out?
70STOVEBOLT 05-24-2025 01:15 PM
That is what I was looking at.
RustyPile 05-24-2025 09:12 PM
An incorrect pulley won't cause a misalignment of the alternator.. I suspect something is causing the bracket to sit at an angle. Perhaps a missing (or extra) spacer or bracket is causing the misalignment.
70STOVEBOLT 05-25-2025 12:52 PM
I thought the issue was pulley misalignment, didn’t realize it was the bracketry that was misaligned.
Steeveedee 05-25-2025 12:53 PM
I was thinking that the angle of the alternator was an artifact of the camera.
pjmoreland 05-25-2025 04:18 PM
Is the front surface of the head machined, or is it a rough cast surface? I'm wondering if these are earlier heads that someone drilled accessory holes in for the alternator.
prateroad 06-02-2025 10:51 PM
Well, I bent the bracket with a tool bar and it lines up now. I do need the alternator if you still have it. The one in pic is off a C50 Chevy and it won't work.
