Intermediate shaft to correct play
1991 C1500. OE intermediate shafts are long gone. What’s the best replacement brand to use? Are there any rebuild kits for the rag joint? Thanks
Re: Intermediate shaft to correct play
Are you talking about the steering? I got an intermediate shaft from the used parts yard. There are rebuild kits for both ends, the rag joint and the cup joint. I have seen where you drill out the rivets to remove the rag joint, the replacement bolts to the flange on the lower end of the intermediate shaft.
| All times are GMT -4. The time now is 04:14 PM. |
