Rear Trailing Arm Bushings: Stock Replacement or Poly?
Hi guys, considering buying poly bushings for my rear trailing arms.
Has anyone utilized these with success? Any additional NHV (noise/harshness/vibration)? The oem rubber bushings are a bit tougher to replace than poly. I'm considering ride quality and no wheel hop when traction is broken. Any advice? Thank you. |
Re: Rear Trailing Arm Bushings: Stock Replacement or Poly?
It is my understanding that poly bushings for body mounts and suspension parts like sway bars, control arms, etc bring with them a level of firmness that many have reported is harsh due to the lack of give and so any forces/vibrations are transmitted directly into the body/chassis. For trailing arms though...it's a good question as I don't see how those joints would experience anything but some fore/aft shock/force with very little twisting action. Not sure what the extra firmness there would gain performance wise though. For a race machine though...you might be looking at a small fraction of a second quicker times in a straight line from the dig. Hth, -Kevin |
Poly bushings still give, just not as much. I've had poly bushings in the rear control arms for about 20 years and it rides and drives just beautifully.
OE style rubber bushings or spherical joints for me. I do use Poly engine & trans mounts.
For sure better than solid :)
| All times are GMT -4. The time now is 01:06 AM. |
