-   -   Anybody using Cold Case Raditor (https://67-72chevytrucks.com/vboard/showthread.php?t=861249)
1970 CST Short Wide 10-20-2025 11:23 PM
I’m looking at Aluminum Radiators with Shroud and Fans for my LS. Came across Cold Case. Anybody have any input on these Or Recommendations
Steeveedee 10-21-2025 12:26 AM
Re: Anybody using Cold Case Raditor
I have one, that replaced my 4-row brass radiator. Dropped right into the stock mounts and fits fine. It's been in there for many years, and I have no complaint.
1970 CST Short Wide 10-21-2025 12:40 AM
Thanks for the input. I’m replacing my 4 row brass also.
lolife99 10-21-2025 01:30 AM
Look on YouTube.
Lots of complains with Cold Case Radiators.
Then read the replies in the comments section for the videos.
Some people are on their second or third radiator.
Joyridin 10-21-2025 07:46 AM
I had 2 of them in my truck. When the 2nd one went bad, I got it warrantied and sold it brand new in the box.
All of them leaked where the header is attached to the tank. The one I put in to replace the CC was about double the price, but have had zero issues.
My brother had the same issue. He just keeps warrantying his though.
HO455 10-21-2025 08:36 AM
I bought and installed one, but I was dissatisfied with how it fit and returned it. I posted the issue in my repair thread in link below. Scroll to post 333.
http://67-72chevytrucks.com/vboard/s...698377&page=14
72c20customcamper 10-21-2025 09:20 AM
I have two . One in my 72 for about 2 years and the other in my 68 . Both fit well and cool well I tow with the 72 and the 68 has a 383 . No problems as of yet . Neither have electric fans just the stock clutch fans
LS short box 10-21-2025 05:25 PM
2 Attachment(s)
I used a Afco generic LS swap radiator on my 68 C10. Biggest I could fit. Worked very well. Some fab to make it fit but not horrible.
Ran super cool. Right on the thermostat.
BROWN 70 10-22-2025 10:42 AM
x 2 post 2. no problems
1970 CST Short Wide 10-22-2025 03:29 PM
Can I ask what Hoses you used. Both top and bottom
LS short box 10-22-2025 05:28 PM
I have since sold the truck to fund a new project.
But my go to for LS hoses is Oreilly's back room hose rack. I make a wire pattern to help select. Typically I have to trim whatever I select to fit.
Rich69shortfleet 10-23-2025 09:53 PM
I don't have one in my truck, but I have Cold Case radiators in both my GTOs (04 and 06) and have been very pleased with both. Fit was drop in easy and they really do a great job keeping things cool. Both run right around 200 degrees at all times. 06 is blown and the 04 has aftermarket heads and cam.
In the truck I have a large Champion all aluminum radiator which was also drop in easy. It looks very similar to the CC radiators and was the final piece of the puzzle to keep my 400 SB cool, especially when towing. It works a whole lot better than the large 4-core brass radiator I had before.
biketopia 10-24-2025 02:36 PM
So what did you put that was twice as much? Currently shopping radiators for my project as well.
Joyridin 10-24-2025 05:05 PM
I used these guys. They have their cores made in the USA and they make the tanks. It wasn't real cheap ($800), but I had my inlet/outlet put on the drivers side instead of the passenger side due to where the L83 hose inlet/outlet is located. The radiator is a work of art.
Summit sells them also. They may have a standard that will work with an original engine or an LS.
https://powercoolmfg.com/street-and-...nce-radiators/
1970 CST Short Wide 10-25-2025 12:40 PM
2 Attachment(s)
Arrived Yesterday. If this goes Bad I will be Very Surprised. Looks Very Well Built. I know looks can be deceiving, But it really does look Well Done
Steeveedee 10-25-2025 02:41 PM
I went and checked my records. My Cold Case radiator has been in my truck 7 years, as of last September.
