-   -   Blower motor screws stripped out. (https://67-72chevytrucks.com/vboard/showthread.php?t=861421)
chrismoore701 11-01-2025 10:11 PM
Dumb question. 79 c10 blower motor screws stripped out. Can i just dab some epoxy in the holes drill out and go? Should i remover the motor? Should i use fiber glass resin?
Dead Parrot 11-02-2025 10:01 AM
Re: Blower motor screws stripped out.
Depending on how much stripping happened, might be as simple as going one size larger on the screws.
straight6chevyguy 11-11-2025 02:47 PM
I agree with dead parrot.
I definitely would first off try going to the next size screw. I believe I have had to do that on one of my trucks.
kennyw 11-13-2025 01:20 AM
Is it a plastic AC box or steel heat only box? Heat only is typically sheetmetal and could be welded shut, redrilled and be good as new. The plastic AC box, I would probably just try to use the next size up.
