Source for Replacement Rear Drum Backing Plate
New to me 1978 axle set...rear drum backing plates are crusty...thought I'd replace, but looking at the Dr Google search results, maybe these are NLA?
TIA for your response. |
Re: Source for Replacement Rear Drum Backing Plate
Learn to speak in sentences?
Well, thank you for that Franken...guess I'll just have to put you in the category of 'I don't have an an answer or suggestion, but I'll be an English/Grammer critic'.
Not all who type and speak the English language are required to meet your standard. The message is quite clear. |
I understood fine, but can't help. I suppose if they don't have holes or rusted out I'd wirewheel and paint.
Need a few more bits of information.
Axle type? 10 bolt, 12 bolt, 14 bolt .... Axle production stamping alphanumeric code. Drum size? |
I'm a few hundred miles away tonight, but will post the stamped numbers when I return.
Knowns = 11" diameter with 2-3/4" wide shoes. |
It is a 12 bolt GM rear axle.
Numbers cast in the housing are GM66 and 3896838 with an N. I looked on the passenger side axle tube for stamped numbers, but apparently the paint on there is a bit too thick? |
| All times are GMT -4. The time now is 07:49 PM. |
