-   -   Were tower style clamps what GM used? (https://67-72chevytrucks.com/vboard/showthread.php?t=862826)
IT Cowboy 02-15-2026 11:42 PM
I still have a few of these style clamps in different areas so I am guessing that is what GM used on hoses for the radiator and cooling system
Steeveedee 02-16-2026 12:23 AM
Re: Were tower style clamps what GM used?
Yup. But the worm gear clamps could be special ordered, and would show up on the SPID. When I worked as a mechanic, we cut the tower clamps off and trashed them, and installed the worm gear clamps. Time is money; at the factory, the tower clamps were faster and cheaper. Tower clamps were really a one-time installation; getting them to release and go back on reliably to not have leaks at the hose connections was an issue.
Rust_never_sleeps 02-16-2026 12:46 AM
Cool. I always wondered why I had some of those and when they stopped being used
Sheepdip 02-16-2026 11:14 AM
Back in my swap meet days I ran across a whole box of brand-new assorted sized tower clamps; I bought the whole thing for $25. Sorted them by size, resold them. I know those clamps made me $300 easy.
davischevy 02-17-2026 11:09 PM
Zoom in and you will see several of the original tower clamps here.
IT Cowboy 02-18-2026 08:36 AM
Wow those clamps are higher than giraffe tits, some a are $10 each or better on some sites if you can find them. Will those style clamps hold if they are new and I replace my worm clamps with them?
clay68c10 02-18-2026 02:12 PM
They'll hold once. Then they might not once you've taken them off. I personally think they're crap and won't use them.
davischevy 02-24-2026 03:44 PM
I use them on all my restorations and they work great.
I reuse them. When loosening, use a deep well socket and push down on the clamp to release it.
mrein3 02-25-2026 02:19 PM
I too used to work as a mechanic. I paid my way through college working for a local shop.
The owner, a good friend until is death, taught us to remove those clamps with a side cutter and replace with a worm clamp after the work is done.
Orange Crate 02-25-2026 10:36 PM
Cant seem to find one in the assembly manual...but I gave up after 40 pages.
Steeveedee 02-25-2026 10:47 PM
^ Tower clamps? I'd not expect the pics to be that explicit, given the cheesy nature of that manual. I've cut hundreds of those things off in my time of mechanickin'! For sure from the mid-'60s into the '70s, they were on GM vehicles. Chrysler had those Corbin clamps for decades. I had pliers for them and those clamps went into the trash, too. Most of the time they broke, anyway.
Orange Crate 02-26-2026 11:20 AM
^^^^^^ Actually there is a lot of good detail. Take a look for yourself. Mostly they used wire wound spring clamps. Again, not one tower clamp illustrated that I could see.
