Chassis Swap Kit 67-72 to Squarebody
Does anyone make a kit to swap a 67-72 C10 to a 4x4 squarebody chassis?
Re: Chassis Swap Kit 67-72 to Squarebody
Unless you are planning on using 3 inch body lift blocks under the core support and bed, I would not recommend it.
Reason being is the frame kicks up forward of the rear cab mounts. Unlike the earlier frames where the kick up is behind the cab. It can, and has been done but using the 67-72 frame is a lot simpler. |
I bought one that is already on a squarebody frame. Just not satisfied with the way they mounted it. Thought someone made a kit for it.
Everything i have seen, it requires a body lift as mentioned. If you have a big tire 4x4 it may look OK, otherwise to me it looks bad.
| All times are GMT -4. The time now is 06:37 AM. |
