'69 307: Large or small journal?
I have an anemic 307 in the beater. If my memory serves me, sbc's used small journal cranks through '67, then large journal cranks '68-up. Is this correct? I'm thinking of using the rotating assembly (minus pistons of course) to build a 327. Just wanted to know which block to look for. Also, would this crank be cast or forged?
cast iron, large journal crank
Re: '69 307: Large or small journal?
Do you mean which 327 block?It would be easier to find a 350 block to put it in. |
Exactly. I just wanted to know if I needed a small-journal 327 block or a large-journal 327-350. Thanks. |
If you build a 327 i have a set of SJ aluiminum rods i am selling.
I am also considering this with mine. 1968 + cranks are large journal. Your crank is cast nodular iron, and that is the only type for the 307. I would just find a good 350 block, as they are everywhere, although a 327 block of course, will work. Try to stay with a block earlier than 1986 unless you want to buy an adapter kit for a one to two piece rear main seal... This later block will have 4 tapped holes and a machined flat above the rear seal area.
The blocks are "basically" the same other then that with a common standard bore size of 4.001". Watch for: Dipstick on the side you want it. Starter motor bolt patterns (2 different size flywheels were used) Block with a casted number 10 over 20 by the camshaft bore is preferred as they have a high tin/nickel content which helps the block breathe and maintain a seal longer. Good Luck |
