09-16-2024, 04:26 PM | #1 |
Junior Member
K20 cab mount bracing with rotted cab mounts
I will need to install the braces to keep the integrity of the cab square before I remove it from the frame. Should I use the door hinges to the floor and the b pillar door lock to the floor as my reference and then left to right frame brace with a level on it to ensure it is square so I can pull it off the frame and leave at that to do the floor replacement ?
Love to hear what other methods have been used. |
09-16-2024, 04:47 PM | #2 |
Re: K20 cab mount bracing with rotted cab mounts
I'm in the process of replacing my entire floor right now. You can read about it in my thread. Below is a picture of my bracing. I went from inner door frame to inner door frame on both doors and then tied those braces together. I did that so I could put the doors back on and test fit with the braces still in place. I don't have it done yet, so I can't speak to the success of this bracing, but it doesn't appear to have moved.
My 67: http://67-72chevytrucks.com/vboard/s...d.php?t=784468 |
09-16-2024, 09:54 PM | #3 |
Search for member May70. He has a good YouTube series on this very thing.
https://youtu.be/5ysUL5ZKtFk?si=cIyP5zaHPyo02TQ5
1972 GMC K2500 Super Custom Matt Last edited by Fbks_Cruiser; 09-16-2024 at 10:06 PM. |
09-18-2024, 03:23 PM | #4 |
Junior Member
Thanks rooster. I also need to swap the roof along with rotted a pillar windshield posts . I got a roof with the a pillars and need to remove the outer skin as it has crew lights
The spot welds do look like they are internal. Ughhhhh |
09-18-2024, 03:42 PM | #5 |
Junior Member
I watched all of MAYCO's videos. I completely forgot that I could use stationary interior spots to base my bracing.
Sucks getting old. Next is figuring out the roof and a pillar to roof posts. |
09-18-2024, 04:31 PM | #6 |
Please post pics: I am going to do the same thing and have no idea where to start.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
09-18-2024, 07:23 PM | #7 |
BlahBlahBlah
Wow you have to replace a lot of metal, floor, roof, windshield posts. Love to seem some pics of this cab you are working on.
09-19-2024, 10:12 AM | #8 |
Junior Member
I will take some pics and post them.
The floor and the interior roof areas |
09-20-2024, 11:23 AM | #9 |
Junior Member
Having difficulty posting pics and I get a error of SECURITY TOKEN.. What is that about ?
I intend to cut half way down the rear window and then see how long I have to cut the pillars. I have the Eastwood Rust Encapsulator that has the long hose with the 360 degree spray tip and will shoot that down all 4 remaining mounts I need to weld the new roof on..The inner roof is complete toast so I kill 2 birds with one task Floor and bottom kick panels have to be addressed. Being a K truck I have the high hump floor |
09-20-2024, 11:32 AM | #10 |
Junior Member
I also intend to use the mesh protector on the cowl and I saw a few guys who added drain slots to the bottom A and B pillars and the rockers. Firewall is rust free.bottom of new floor gets Encapsulator and then scoffed with 220 and a few coats of base color . I may do the same with the bed
09-21-2024, 07:17 AM | #11 | |
