Old Yesterday, 07:54 PM   #1
dmjlambert
dmjlambert's Avatar
Re: I just want to drive my truck, need some help!
Also make sure the vacuum port the distributor is connected to is manifold vacuum. You can tell because when idling and you connect or disconnect the hose it will change the idle speed. When connecting/disconnecting it to a ported vacuum source, it won't affect the idle speed. With the hose connected to manifold vacuum, adjust the idle speed to 700 to 800.
