Old 08-06-2024, 01:05 PM   #1
Hart_Rod
Hart_Rod's Avatar
Fuel pump module/sending unit
I need to replace the fuel pump module/sending unit in my 84 C10 LT swap. Any thoughts on if this Aeromotive unit 18379 for an 88-98 Chevy truck might work? Is there a big difference between the two tanks? Here's the link to the Aeromotive unit: https://aeromotiveinc.com/products/f...m-pickup-truck
Hart_Rod is offline   Reply With Quote
Old 08-07-2024, 02:24 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Fuel pump module/sending unit
Someone on FB recommended this:
https://www.highflowfuel.com/fuel-pu...fs-h880-0-qfs/
I ordered one and we'll see...
Old 08-29-2024, 11:08 PM   #3
KFF 1
KFF 1's Avatar
You could build you own unit that will drop in your tank. Precision FG05N is the sending unit for 87 squarebody. Holley sniper fuel pump 19-369. hope this helps
KFF 1 is offline   Reply With Quote
Old 09-19-2024, 09:28 AM   #4
Hart_Rod
Hart_Rod's Avatar
Thanks for the information. I ordered the high flow setup. It's been installed for a couple hundred miles. So far so good. If I have any issues, I'll build my own next time. Take care,
Rob
