Old 06-12-2024, 03:11 PM   #1
burlapen
burlapen's Avatar
Lots of Resistance When Turning Hard
Hey Guys!
Finally getting my truck out for some test drives after a frame off. It's a 63 longbed that I converted to short. It has a 5.3 and T56 manual. I used the front crossmember, suspension and disc brakes from a 72 c10. When I put the chassis together I measured the toe the best I could with a tape measure. The truck still had a lot of rolling resistance when turning. So I took it in and had it put on an alignment machine. It still has the same issue. You can hardly take off with the wheel turned hard in either direction without stalling the engine. I did have to drill the frame for the idler arm from the 72 which I completely eyeballed as I couldn't find any specs on where the holes should go. Opinions? Thanks in advance.
63 Chevy C-10
My build thread
burlapen is offline   Reply With Quote
Old 06-12-2024, 06:01 PM   #2
Richard
Re: Lots of Resistance When Turning Hard
Originally Posted by burlapen View Post
Hey Guys!
The most common cause of this is the center link being installed backwards. I looked through your thread and could not find any clear pictures of it installed. Nuts on ball joints should face forward.
Richard
Old 06-13-2024, 09:54 AM   #3
burlapen
burlapen's Avatar
Thanks for the reply. I’ll try to double check. This is the way I have it installed currently.
63 Chevy C-10
My build thread
Old 06-13-2024, 10:12 AM   #4
burlapen
burlapen's Avatar
Based on some other pictures I'm pulling up, It appears I may in fact have it backward. I guess that's what happens when you take something apart and try to remember how to put it back together years later. Going to try flipping it and see what happens.
63 Chevy C-10
My build thread
Old 06-13-2024, 01:41 PM   #5
Richard
It is backward. Ball joints on endlinks go toward the crossmember with nuts forward.
Richard
Old Yesterday, 06:14 PM   #6
burlapen
burlapen's Avatar
Forgot to jump back on here to confirm the correct diagnosis. It was in fact backward!! Thanks for the help.
63 Chevy C-10
My build thread
