Old 02-11-2013, 02:33 PM   #1
JFetter
What do these wires do? Neutral/Safety Switch
Hello,
My reverse lights have not worked since I bought the truck. (78 K10, auto)
After tracing down the wiring, I found that my neutral safety switch is totally missing. New one on the way...
So I'm pretty sure the light green and dark green connector is for my reverse lights.
Then there are the yellow and purple/white, which have been connected together. This if for the start circuit?
Then that leaves this purple wire all by itself not being used. Does this belong on the neutral safety switch?
Thanks!
1978 K10
JFetter is offline   Reply With Quote
Old 02-11-2013, 03:33 PM   #2
rs72z
rs72z's Avatar
Re: What do these wires do? Neutral/Safety Switch
The 2 purple wires are the starter circuit. The yellow wires has been added. Does it go to the starter?
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 02-12-2013, 01:26 AM   #3
kustomrust82
kustomrust82's Avatar
i believe mine were yellow and purple, 82 dually. my coloum was worn out so it was hard to line up the shift to start it so i looped the safety switch. just have to remember to not staart it in gear lol
'82 c10 shortbed drag truck
'82 GMC 3500 Dually DD scrap truck
'55 Chevy 210 4 door sled
'65 VW Bug Rat Rod
kustomrust82 is offline   Reply With Quote
Old 02-12-2013, 10:39 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
79 auto
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 02-12-2013, 10:45 AM   #5
hatzie
Moderator
hatzie's Avatar
First image is the Backup light plug.
Not sure where the yellow wire came from... Got an extra ignition switch plug?
1978 PPL/WHT is Circuit 5 the start position on the ignition switch. PPL Circuit 6 goes to the bulkhead plug and then the start lug on the starter solenoid.
1979 YEL is Circuit 5 the start position on the ignition switch. PPL Circuit 6 goes to the bulkhead plug and then the start lug on the starter solenoid.
You can find the GM schematics in my sig.
BTW according to the schematics it shouldn't start.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 02-12-2013, 12:09 PM   #6
rs72z
rs72z's Avatar
I need to look at my 78 i dont ever remenber seeing a neautral switch with different color wires till now.
___________________
78 ccsb dually
5.3
4l60e
Old 02-12-2013, 12:40 PM   #7
rs72z
rs72z's Avatar
Not sure when they changed them but my 78 has 2 green wires.
Just now saw the post above, there's my answer.
___________________
78 ccsb dually
5.3
4l60e
Old 02-12-2013, 03:52 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
knew i'd seen yellow but couldn't find the 78 before,just took another pic
78 auto
John
Old 02-12-2013, 04:52 PM   #9
JFetter
Hmmm, the plot thickens.
So 78 has both wires purple, in the start circuit.
It's almost like a 79 steering column is installed?
I'm going to have to trace some of these down and let you know what I find.
Thanks guys!
1978 K10
Old 02-13-2013, 06:43 PM   #10
JFetter
Just an update: The purple wire that is not currently being used must have gone bad at some point an PO just left it there. He then ran a new yellow wire to the starter.
Just got my new Neutral switch, connected everything and success! We have reverse lights.
Thanks!
1978 K10
Old 11-29-2015, 12:01 AM   #11
HotRod C/10
HotRod C/10's Avatar
Bump for N2Trux
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 11-29-2015, 12:48 PM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by HotRod C/10 View Post
Bump for N2Trux
Thanks for the bump. I will be back under my dash soon.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-29-2015, 08:14 PM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
What I was able to determine after in depth investigation is the plug that I have loose doesn't go anywhere. It has a jumper built, so it goes no where.
Articles-
"Refining Sierra"
Old Yesterday, 11:55 PM   #14
kitsbeach
kitsbeach's Avatar
Originally Posted by motornut View Post
79 auto
I'm reviving an OLD thread because it has the good info...
My question is what holds the switch to the column? Can I buy the clips in motornut's picture?
Name:  1979 J2Gs 0178.jpg
I'm converting my 1980 C20 from manual to automatic and this is what my manual trans safety switch looks like. Seems I'll be able to transfer the manual purple and yellow plug to the new automatic switch and I will have Park and Neutral safety.
Name:  1980 C20 manual clutch safety switch.jpg
This is what the automatic trans switch looks like new from rock auto.
Name:  ACDELCO D2220C NEUTRAL SAFETY SWITCH.jpg
The wire for my backup lights is under the floor hump near the shifter. No sweat to extend those wires to the automatic switch but can I find a plug and re-pin it? Or will I have to just spice wires (not as pretty)?
Any clues would be appreciated
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
1980 C20 Long to short & static drop "Square One"
kitsbeach is offline   Reply With Quote
Old Today, 12:28 AM   #15
kitsbeach
kitsbeach's Avatar
Here's some pictures from a Haynes manual on the subject. Talks about screws but looks like I need clips of some sort for the screws to screw into.
Kitsbeach (Ken)
