Old 08-17-2024, 07:39 AM   #1
dennislbrooks
dennislbrooks's Avatar
Electric Wiper on 59 GMC Fleet
I used LMCs electric wiper conversion to replace the oe vacuum setup. My 59 GMC should be like at least the 58 if not near all 47-59. It is maybe somewhat a universal kit for those years. It has adjustments.
I like the 2-speed kit and LMC had good pricing. I did have to remove both existing arm bushings that mounted to the stock motor arm. (I did in truck) Then you use all the bushing supplied on new motor arm, It is a good idea to fit the 2 allen wrenches to the arm adjustment. If they do not point down when mounted, rotate before you do the initial install. Remove wiper blade arms beforehand also. They are near the last to put back on.
My stock black plastic knob would not work as it is hex and the switch is half-moon but they do send a chromed stock like brass knob that I will blast and paint black sometime.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 08-17-2024, 12:29 PM   #2
JDarby
Active Member
Re: Electric Wiper on 59 GMC Fleet
Looks great!
The LMC universal Wiper mount looks to be pretty straight forward!
It's nice when you don't have to re-direct linkage to make things work out for you, especially under a dash board!
I have decided to stick with my vacuum wiper motors for the first re-birth of my RestoMod.
The 2 speed kit I bought off of Ebay would not fit in my truck because of my AC unit and too much time had passed before I could make a return.
Will have that up for grabs after my build completion.
1955.1 GMC 100 RestOMod
1972 T120RV
1967 C200 Trail 90
2014 TRD Quad CAB
JDarby is offline   Reply With Quote
Old 08-29-2024, 07:11 AM   #3
dennislbrooks
I run the Trico 141 wiper blades on my 67 and will use Trico 131 blades on the 59 as opposed to stock style blades. I know there are other types but these conform better to the windshields. Anyone have other preferences for actual working blades?
The Trico 131s did not connect correctly. I had to modify with attachee on old stainless blades.
