Old 06-23-2024, 08:36 AM   #1
A1971Blazer
A1971Blazer's Avatar
Fan issue with AC trinary switch
'67 C10 with '02 LS1
I'm running the Entropy LS swap radiator with dual fans.
Fan 1 is wired to the PCM only, it triggers the relay at 195º, it works perfectly.
Fan 2 is also wired to the PCM to trigger at 205º and it's also wired to the trinary switch and connected to the same trigger (ground).
The fan will come on via the trinary switch or the PCM or both ( I assume)
I'm getting a code P0481 (fan 2) when I have the AC on and the PCM triggers the fan 2 relay. I did find a loose connector in my load center for the fan 2 relay but I fixed that.
I'm wondering if the trinary switch and the PCM fan trigger being wired together is causing the issue, and what is the best/easiest way to correct it?
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 06-24-2024, 07:05 AM   #2
A1971Blazer
Re: Fan issue with AC trinary switch
My go-to source for tons of information....good old YouTube, it's better than 4 years of college...
I quickly found an easy way to wire the fans and separate the PCM trigger and the trinary switch trigger.
I had the idea I just wasn't sure of the exact connections.
It's similar to the way I wired the high/low beam headlight relays.
Name:  fan wiring 1.jpg
1967 C10 Step side
1968 C10 Step side
Old 06-24-2024, 07:05 AM   #3
v30crewcab
v30crewcab's Avatar
computers don't like additional stuff. you need to wire it thru a relay were its either or, not wired together.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 06-24-2024, 07:08 AM   #4
A1971Blazer
thanks....see post#2
1967 C10 Step side
1968 C10 Step side
Old 06-24-2024, 09:58 PM   #5
v30crewcab
v30crewcab's Avatar
cool, thats how I was thinking just wasn't sure how to explain it!
71 longbed 5.3 4l80
