Old 07-21-2024, 03:05 AM   #1
Bobillot
Bobillot's Avatar
Exclamation In need of 283 .030 pistons
Hello Im in need of some 30 over pistons for my 283 truck engine I have some but they are 0.057 at tdc below the deck. I just had the 283 bored and honed to 3.905 and have a new everything for it. But I noticed the deck seemed high and I checked out the new and the old STD pistons.
The new to this engine 30 over pistons have a compression height of 1.78 and the originals have a height of 1.83. So with these pistons its a substantial hit to comp ratio and the engine is going back into my 1975 C30 hay hauling flat bed dump truck so it needs all the power it can get.
It would get us back hauling hay more efficiently. Thank You for any help!
Bobillot is offline   Reply With Quote
Old 07-21-2024, 01:30 PM   #2
truckdude239
truckdude239's Avatar
Re: In need of 283 .030 pistons
i can find 1.80 compression height, but i see nothing at 1.83 https://cnc-motorsports.com/keith-bl...ore-3-905.html
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 07-26-2024, 02:44 PM   #3
scottofksu
scottofksu's Avatar
It might be cheaper to have the block decked... Dial in your compression ratio by decking to the preferred compression ratio relative to your piston volumes and head gasket selection. What heads are you running and do they have good squench potential given your piston surface characteristics? Good luck, brother! I hope your hay hauler gets back up and running stronger than ever before sloppy weather hits!
Travis' Tribute Truck - 65 C10 Frame Up Restoration
http://67-72chevytrucks.com/vboard/s...d.php?t=495073
scottofksu is offline   Reply With Quote
Old 07-26-2024, 06:37 PM   #4
Accelo
Accelo's Avatar
Your pins and rings have been installed and the block bored to the pistons. So no returns. I assume you are attempting to salvage all the work you have completed.
Other pistons may not fit the block. Forged or cast pistons take wildly different piston-to-wall clearances.
I did the same thing years ago. When I read the "* fine print" It mentioned the lower compression height. In my case, it was .020 lower.
This is done so the people who deck the block are not running into piston clearance issues.
I agree "It might be cheaper to have the block decked". That typically includes the intake manifold machining but not always. Decking the block requires disassembly.
Possibly you can find heads with smaller combustion chambers. That leaves the quench quite large and not conducive to power production.
As an interesting comparison, LS motors have the piston sticking out of the bore at a nominal .005 to maximize the quench.
Accelo is offline   Reply With Quote
Old 08-07-2024, 05:12 PM   #5
mattfranklin
mattfranklin's Avatar
In rough back-of-the-envelope calculations...
Dang, that's 6cc! About 10% of a 64cc chamber.
and maybe worth a point of compression ratio?
Rough rule of thumb the Car Craft and Hot Rod magazine guys used to repeat was that each point of compression ratio was worth about 4% of free horsepower. (For more detail search out the classic SAE paper on that topic by Caris and Nelson at GM in the late 1950s).
Could any of us notice a 4% difference? I know it's not perfect and would probably bother me. But what's the cost of getting it right? Just putting it out there. It would bother me enough to fix it, but sometimes I make decisions out of passion for the hobby, rather than on engineering economics. :-)
EDIT: Here's a link, but they make you pay -- https://www.sae.org/publications/tec...ontent/590015/
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 08-08-2024, 09:41 AM   #6
THI
Active Member
THI's Avatar
Silv-O-Lite cast have a compression height of 1.779 and Keith Black hypereutectic have a compression height of 1.805
THI is offline   Reply With Quote
Old 08-11-2024, 08:11 PM   #7
Willshook
really don't wanna run with that kind of quench, which is even worse when you add in even a thin head gasket. So it's not just about the pistons compression height.
Take it apart and get it zero decked. run an~.040+ gasket.
Willshook is offline   Reply With Quote
Old 08-15-2024, 04:20 PM   #8
GSP7
GSP7's Avatar
Originally Posted by scottofksu View Post
It might be cheaper to have the block decked... '..................!
No! do not do that
Just go buy the correct pistons
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
Pinstriping-Lettering-Specialty Painting
GSP7 is offline   Reply With Quote
Old 08-17-2024, 05:19 PM   #9
66 C10 383
I have the same dilemma with a 383 I had a guy machine & assemble for me. The pistons were chosen with the head gaskets for. 045" quench. Long story short, he didn't zero deck the block like I asked him to. Found out later my pistons are
017" down from TDC.
I hadn't installed the engine or even fired it up but he's out of business now.
Since it's a 2pc rms block & I'm running hydraulic roller cam I thought about just putting everything along with a different 3.75 crank into a 1pc rms roller block.
Doug
Old Build Thread - 383/T56
http://www.67-72chevytrucks.com/vboa...d.php?t=540838
Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua
5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital
http://67-72chevytrucks.com/vboard/s...d.php?t=778784
66 C10 383 is offline   Reply With Quote
283, 3.905", pistons
