Old 10-03-2022, 10:03 PM   #76
cwcarpenter98
cwcarpenter98's Avatar
Re: 60-66 Trailer made from a 60-66 bed
Originally Posted by D'Monsta View Post
More pics.
Sweet! I like the dual gate idea
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 10-04-2022, 02:50 PM   #77
350TacoZilla
I like the twin tailgate idea. It would also be nice if you were loading truck bed with trailer attached so you could just load through the trailer with small ramps or something.
350TacoZilla is offline   Reply With Quote
Old 10-07-2022, 09:00 PM   #78
D'Monsta
D'Monsta's Avatar
Yes, I do that too.. and when both gates are down there's 12 feet of platform.. This thing is great, It's like having another work truck..
D'Monsta is offline   Reply With Quote
Old 03-16-2024, 03:53 PM   #79
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Old thread, but the one having the most posts
How do these trail?
I have a utility trailer that you have to load correctly or it'll really start whipping around.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 03-17-2024, 04:05 PM   #80
350TacoZilla
Pretty much any single axle is going to be more sensitive to weight distribution but we have built 3 truck bed trailers (no 60-66 unfortunately or would that be fortunately?) and they pull pretty well and seem less prone to wagging than my 5x8 utility trailer but I think we always had longer tongue's on them. We would cut the truck frame right behind the middle cab mounts and V the frame in right infront of the rear cab mount.
Old 03-18-2024, 09:33 PM   #81
cwcarpenter98
Mine pulls really well, but I do take care to have a somewhat ideal weight distribution. I haven't had any issues with trailer sway, and that could be because it's built similar to how 350TacoZilla would build them. The original truck frame and 8 foot bed in my case provides a decent weight distribution loaded or unloaded from what I've experienced
Christian Carpenter
Old 06-05-2024, 11:00 PM   #82
LostMy65
LostMy65's Avatar
Originally Posted by kerber63 View Post
Here's mine that I've had for years, I just built the stake sides for it. '63 longbed with coils and helpers. It's hauled a lot for me.
I like how you used the brake handle and brakes.
Great idea so you don't have to always chock the wheels.
Old 06-06-2024, 12:00 AM   #83
LostMy65
LostMy65's Avatar
How hard is it to bend the frame in?
Does it need to be heated with a torch?
Old 06-06-2024, 06:00 PM   #84
350TacoZilla
So we have heated just the top and bottom of the C channel and then folded them in using a pipe for leverage at the front and one we cut small notches in top and bottom and folded in then welded the seam up. I keep thinking all of them had a small flat bar crossmember welded across the top right at the bend point also to reinforce the area.
Old 06-06-2024, 08:47 PM   #85
LostMy65
LostMy65's Avatar
Perfect! Thanks!
Old 06-19-2024, 08:29 PM   #86
LostMy65
LostMy65's Avatar
How much do you think these could carry?
C10 = 1/2 ton?
Old 06-25-2024, 03:09 AM   #87
350TacoZilla
Probably the safe way to figure would be to go off what the axle and springs are rated for. If you put a trailer axle under it with brakes the frame and suspension would have no problems with more weight, the functional trailer brakes is a big part of what I would feel safe hauling. We mainly used ours for landfill runs, home improvement store pickups, mowers etc like you would a small 5x8 trailer like I currently have so maybe 1ton upper limit? Though I'm sure there were a few times where we were pushing way past that with firewood in both the pickup and the trailer stacked up to the top of 2ft sides on beds.
Old 06-25-2024, 11:50 PM   #88
LostMy65
LostMy65's Avatar
Thanks.
Yeah, mine will rarely be taken on the road. It'll just be used around my property. Firewood and dirt.
I was just curious. Mine is a C20 with a 73+ 14-bolt Rearend.
Old 10-24-2024, 09:40 PM   #89
LostMy65
LostMy65's Avatar
Here is all I have left from the 66.
Hope to get to the welding this weekend.
Old 10-24-2024, 10:26 PM   #90
Getter-Done
Getter-Done's Avatar
Great work.
I have a couple that are built similar to what you are doing.
Fish plates, Bolts and stich welds are your Friends.
84 Chevy K-20
Old 11-04-2024, 02:02 PM   #91
LostMy65
LostMy65's Avatar
I took a load of scrap to the scrap metal place. 1000 pounds. It trailed really nice.
Old 11-04-2024, 03:21 PM   #92
kerber63
kerber63's Avatar
I recently did a large bathroom remodel. Took everything to the landfill in one go... half ton D44 with 1 extra leaf, I dropped 2,800 pounds off, yikes. Pulled like a dream and squatted nice and level. But she did squat a LOT.
1963 C10 short-wide
Turbocharged 454, T56, 4.11 posi
http://67-72chevytrucks.com/vboard/s...d.php?t=605408
1963 C10 suburban
Unknown, unknown, 3.73 open
http://67-72chevytrucks.com/vboard/s...d.php?t=622037
kerber63 is offline   Reply With Quote
Old Today, 01:16 AM   #93
LostMy65
LostMy65's Avatar
Slammed! 😄
