Old 07-17-2024, 11:10 PM   #1
jollymon02
Junior Member
TBI motor tuning
Hey all,
I have a TBI motor running a aftermarket EFI and mild cam. I'm working to get the tuning sorted out. I currently have an HEI distributor with vacuum advance, but have the option to change for a billet and let the EFI handle the timing control, which would make it more like an upgrade from the factory air/fuel delivery.
My immediate question is where should I set the base timing, 0 as factory, or more like a typical SBC 8 degrees base?
jollymon02 is offline   Reply With Quote
Old 07-18-2024, 07:49 AM   #2
biketopia
Re: TBI motor tuning
What EFI controller? The holley setups have you index the distributor a certain way, lock timing out to a certain number in the tune then verify it stays there at idle and revving it up. Once that's done you do all your timing curve adjustments through programing only. If you set it at 8, the EFI program thinks it's base line is "0" and puts in 8 degrees now your at 16 and having tuning issues.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 07-18-2024, 09:10 AM   #3
jollymon02
Junior Member
It is Fitech. Same basic principle. I'm asking if there is a known difference in the tbi vs carb motors calling for different timing for an aftermarket efi. Last distributor car I had was a 70s 2L BMW, so the SBC world is not stored in my brain.
Old 07-18-2024, 03:50 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Depending on the cam it's gonna need some advance. Start out with 12 degrees or so. The adjust from there. After a few test runs (driving it with a load on the engine), see where the sweet spot is. Small Blocks love advance. However, the TBI "swirlport heads" might negate the gains a bit. They were designed with the severely underpowered TBI in mind.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 08-11-2024, 06:19 PM   #5
PbFut
I beleive FiTech wants a 10 degree locked out setup. No vac advance, no mechanical. The spark control in their program will manage advance. I recall their max electronic advance is 22 degrees making total max 32. If you don't need 32 on top, you might be able to drop initial and let the computer manage srart up to a greater degree. I am unsure if their system adjusts startup advance.
PbFut is offline   Reply With Quote
