Old 06-03-2024, 08:41 PM   #5401
lgh1157
Re: What did you do with your truck today, Part 3
I finished this bed :
lgh1157 is offline   Reply With Quote
Old 06-03-2024, 08:42 PM   #5402
lgh1157
Another pic
Old 06-03-2024, 09:25 PM   #5403
leegreen
I put mine back on the road for the summer. Now with power steering, improved cooling and a somewhat better hood fit. Still a long list of things to do, but I get to drive it now.
leegreen is offline   Reply With Quote
Old 06-03-2024, 11:25 PM   #5404
dsraven
Post 5402, my eyes are wonky from a quick look. How are yours after doing that work?
Old 06-04-2024, 12:56 PM   #5405
nvrdone
Had the left rear brake hang up on the way to a show Saturday. Pulled it down and found the spring on the adjuster wheel had broken. Replaced all the hardware on both sides along with all brake shoes and had the drums turned. Now the brakes seem to be working much better.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's
Bought in 1973 for $235.00. Had it longer than my wife & Kids!!
nvrdone is online now   Reply With Quote
Old 06-05-2024, 07:57 PM   #5406
idbeast
So, I bought a 3d printer to made some things for the beast, a different center console cover, and speaker covers for the cab corner speaker box's.
Then I got the back-up camera working with the 9" touck screen navigation stereo!
idbeast is offline   Reply With Quote
Old 06-06-2024, 12:01 PM   #5407
leegreen
your dash looks pretty good for a modern update of 50s truck. I'd like to see a zoomed out picture of the whole thing?
Old 06-06-2024, 01:15 PM   #5408
idbeast
Here you go!
Old 06-06-2024, 03:17 PM   #5409
mr48chev
mr48chev's Avatar
I did drag the dash I am going to put in mine out and take some photos to post on a FB group to try to find a part that I need for it. It was the original dash in the first car I ever owned that I replaced with a dash out of a parts donor car in the late 70's and saved back.
I figured out that I also need to straighten out a couple of pieces on it that I bent back when I was 19 and thought I wanted to make a varnished wood dash with round gauges for it.
My shoulder is getting pretty well healed up and I might actually have a progress report in a couple of weeks.
My ongoing truck projects:
Old 06-06-2024, 03:38 PM   #5410
leegreen
idbeast, you made it look like it belongs there. well done
Old 06-06-2024, 06:47 PM   #5411
vintovka
vintovka's Avatar
Busy week. Replaced all the spark plugs, did a tune up, replaced shocks, door hinges, and upgraded Halogen Floods to LEDs. Pics and particulars on project link below
vintovka is offline   Reply With Quote
Old 06-08-2024, 04:23 PM   #5412
JDarby
Active Member
Originally Posted by dirty dish View Post
Attachment 1565996finally got tires mounted and put on had to mount them by hand wouldn't fit on tire machine
Wholly ****!!!!!!!
Talk about MonSteR TrUcK!
1955.1 GMC 100 RestOMod
1972 T120RV
1967 C200 Trail 90
2014 TRD Quad CAB
JDarby is offline   Reply With Quote
Old 06-08-2024, 04:26 PM   #5413
JDarby
Active Member
Originally Posted by lgh1157 View Post
Another pic
SeXY!!!
1972 T120RV
1967 C200 Trail 90
2014 TRD Quad CAB
Old 06-08-2024, 04:54 PM   #5414
JDarby
Active Member
Attachment 2365146
Very nice looking truck!
1972 T120RV
1967 C200 Trail 90
2014 TRD Quad CAB
Old 06-08-2024, 11:09 PM   #5415
nvrdone
Well, I got the sticking rear brakes figured out & fixed, so I figured I'd take a run to a local swap meet. When I got there, I checked the temp at the hub and it was 119 deg on the left and 126 on the right. Didnt have any brake drag. Thought all was well. Boy was I wrong! When I got home the left hub was at 219 and the right was at 130. There was some smoke coming from the left brake, so off came both drums. No problem on the right but the left axle bearing made a terrible grinding noise. Looks like tomorrow I tear the axle apart to start a complete rebuild. Wish me luck.
Old 06-09-2024, 11:01 AM   #5416
mr48chev
mr48chev's Avatar
If it has the axle that has the bearing running on it you may need an axle before all is said and done.
Old 06-09-2024, 11:10 AM   #5417
nvrdone
its got a 12 bolt out of a c10 so I'm not sure how the bearings go on. I will figure it out & get it fixed. Maybe I will end up building that 9" I want.
Old 06-09-2024, 11:14 AM   #5418
dsraven
it's best to do a complete differential teardown when an axle bearing goes out. a lot of the filings can find their way into the rest of the housing and other bearings can be affected. I always take the whole thing apart, check bearings etc, clean everything up, replace what needs to be new and then assemble. I use a garden sprayer to clean inside the axle tubes. a small rotary wire brush on a long rod works well, with a drill to drive it, to clean down the axle tubes if there is debris there. a long rod with a long nut, like the threaded rod connector nut, works well and then i usually thread the end of the wire brush so it can be threaded onto the rod.
good luck, hope it is just a bearing. there are repair bearings made if you find your axle is chewed up, but then a new axle likely wouldn't break the bank either.
post up some pics when you get tht far.
Old 06-09-2024, 11:15 AM   #5419
dsraven
Old 06-09-2024, 11:19 AM   #5420
mr48chev
mr48chev's Avatar
I actually made a deal for the piece I need for my dash for my 48.
This has been kind of a secret squirrel thing with me but without telling what it is out of the top photo shows the piece the guy cut out and is sending me to replace the piece I cut out of my dash when I was 19 in 1966 with the screwball idea that I was going to put in a varnished hardwood dash that looked like what was in 66 GTOs at the time.
I had saved this dash in the shed ever since I took it out of the car in the late 70's early 80's and put a complete dash out of a donor car that had sat upside down behind the old mechanics shop in Bickleton Wa Across from the Bluebird cafe. We went up with my buddy's rollback truck and winched it on the truck still upside down and strapped it down and went across the street to get some coffee because it was seriously cold that day. I stripped the parts off that body for my car and then sold the hulk to a friend of his from Canada who paid him good money to haul it to Canada. It might be running around BC with a Carson top on it these days.
I'm amazed at how much I hacked out of that old dash. I got a nice instrument panel and rebuilt 6 volt radio from a guy in Bend Oregon a couple of years ago for it and this piece will let me get the dash together.
I'll let folks figure out what it is out of on their own though.
Old 06-19-2024, 04:34 PM   #5421
nvrdone
Wow did i get lucky !! I've got a 12 bolt c10 rear axle in my truck. Last week, I started getting a loud grinding noise out of the left rear wheel. When I got home the axle hub was at 219. so I started pulling it apart. found the left axle bearing was missing one roller. Looked inside both axle tubes with a flashlight and magnetic probe. Nothing. One of my friends suggested before we tear it down, I flush it with carb cleaner and see what comes out. Sure enough the missing roller dropped into the housing. So now, we tear it down and replace all the bearings. I feel like I should buy a lottery ticket!!!
