Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 06-30-2024, 02:35 PM   #1
Orange Crate
Orange Crate's Avatar
Electric Fan Connector
I just installed this fan
http://67-72chevytrucks.com/vboard/s...d.php?t=254617
Does anyone have the part number for the two pin fan connector? I am looking for the other half.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...
Orange Crate is offline   Reply With Quote
Old 06-30-2024, 06:19 PM   #2
Orange Crate
Re: Electric Fan Connector
Here is what it looks like.
Old 06-30-2024, 08:23 PM   #3
Accelo
Accelo's Avatar
Since it's listed as a Chrysler fan I would look in the junkyard for it.
I would be awful temped to just cut the plug and add my own from the parts house.
How about a Trailer Connectors 2-Contact Flat like this one?
https://www.napaonline.com/en/p/NW_784640
Accelo is offline   Reply With Quote
Old 06-30-2024, 08:34 PM   #4
Orange Crate
I'd like to stick with the original, it is rated for the current draw. I am guessing the fan runs at 20-25 amps. I could probably put a lot of different connectors on there but if I have to replace the fan then I also would have to change the connector (again), so one and done if I can just find that part number. I don't have access to a parts book for a Grand Cherokee.
Old 06-30-2024, 09:08 PM   #5
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
what year make model is the fan from?
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 06-30-2024, 09:12 PM   #6
Orange Crate
2000 Grand Cherokee
Old 07-01-2024, 07:42 PM   #7
Orange Crate
Ok, that only took three days and ten emails, but here it is. I ordered two since they were low cost and the shipping was the same for one as for two. I don't have it yet so it could turn out to be a POS or not fit. If it is the right one then I can change the fan out quickly with two bolts and the one connector. I like the idea of the kit without wires as I can try to stuff 12 or 10 gauge wire in there. I have the correct ratcheting crimper for the terminals so...Their site is kinda sketchy but I paid with paypal so if there are any problems I'm covered. On to the relay and temp switch set up now.Enjoy
http://www.autolumination.com/wiring...nector-kit.htm
Old 07-02-2024, 12:11 PM   #8
scottofksu
scottofksu's Avatar
I found that Rockauto seems to have them too - yes, I know I am like a blister showing up after the work is done, but I just found your post! LOL
Here is the link if it helps anyone else:
https://www.rockauto.com/en/catalog/...connector,2556
Travis' Tribute Truck - 65 C10 Frame Up Restoration
http://67-72chevytrucks.com/vboard/s...d.php?t=495073
scottofksu is offline   Reply With Quote
Old 07-05-2024, 03:24 PM   #9
Orange Crate
Alrighty then, the connector is the correct one. Check the link above for the vendor. I think I can shove 12 gauge wire in the terminals, I'll solder them also for a good joint. We'll see if they can handle the current....Looking at a PWM controller and also a trinary switch for the AC compressor, so I might be able to add a manual switch for water crossings (off). Enjoy!
Old 07-07-2024, 07:27 PM   #10
87chevy.com
that ad shows 18 gauge wire, so good luck getting 12ga in there. maybe dealer has terminals available. I know BMW has most of the terminals available.
As far as trinary switch, what do you need it for, HI pressure cut off or LOW pressure cut off?
Old 07-07-2024, 10:02 PM   #11
Orange Crate
I did get 14 gauge in there and ran the fan for 30 min with no heating at the wires so the length must be correct for 14. !2 was definitely not going in that case. The trinary protects in both high and low pressure situations. I like the option of the manual switch in this diagram. I have a PWM fan controller coming so we will see how that manual override can be added to it. I also have the option of controlling a fan through my FI system. The fan swap to electric is a new project that I hadn't really looked at too hard so I'm kinda making this up as I go along. My old clutch fan wasn't going to work since I moved my engine forward for the five speed.
