Old 10-13-2019, 12:03 AM   #701
mongocanfly
mongocanfly's Avatar
Re: Project "Popeye"
what kinda gas you running in it?..octane?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 10-13-2019, 08:09 AM   #702
LEEVON
Moderator
LEEVON's Avatar
Just 87 octane that I had in a safety can. I plan to go fill it up with 91 ethanol free and see if that helps. Is that what you are thinking?
Also going to bump my idle speed down a hair and play with the timing.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 10-13-2019, 02:33 PM   #703
mongocanfly
Yeah...its one solution...but may not fix it...
I copied this...
Dieseling is a common problem, especially in warm weather or when the engine is hot. In this case, it is usually caused by running "cheap" gas with inadequate octane. In this case it can usually be remedied by switching to a higher octane fuel.
In milder street engines, another big cause for engine run-on is having the idle set too high, or the carb is misadjusted which requires the idle speed screw to be screwed-in too far to allow the engine to idle. When the idle screw is screwed-in too far, it opens the throttle plates too wide and actually pulls fuel through the main jets a little, so when you shut the engine off, the inertia of the spinning engine still pulls air (and some fuel) through the carb and into the cylinders and the heat built-up inside the combustion chambers is enough to light a few of the cylinders at random to keep the engine spinning and sputtering. Again, this is especially true with fuel that isn't high enough in octane. The more the octane, the less volatile the fuel. Even though the key is off, the engine won't stop sputtering because the throttle plates are opened up enough to still pass a little fuel and air
Fuel injected cars don't have any Dieseling or run-on problems because the fuel is electronically pushed to the injectors via an electric fuel pump, and the injectors electronically fire, so with the key off, the fuel delivery completely stops. Carburetors aren't electric, so even when you shut off the ignition, the inertia of the engine still rotating is still sucking-in a little air and fuel, and as long as it is still rotating
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-14-2019, 10:17 AM   #704
99 to Life
99 to Life's Avatar
You sort out trans controller? I haven't gotten any dieseling with my carbed LS on crap gas. Last SBC I did was pretty good about it and hot starts. My first truck I did 355 with crap heads dieseled and hot started like crazy. All used eddy 600 cfm carb. Congrats, enjoy driving it really loved seeing this build.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 10-30-2019, 09:08 PM   #705
Tinbasher
I read thru this whole build in a couple days... man your truck is addicting! good job i love your truck!
Tinbasher is offline   Reply With Quote
Old 09-29-2024, 10:50 PM   #706
LEEVON
Moderator
LEEVON's Avatar
Popeye and I are still around! He’s been in the back of my shop for almost two years. I recently dug him out and have been driving him. Did a couple of shows and some donuts on my street establish neighborhood dominance. My youngest has claimed the truck. Time flies fellas
Old 09-30-2024, 11:21 AM   #707
SCOTI
SCOTI's Avatar
Nice! Good to see it's still in the game.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-04-2024, 09:13 AM   #708
youngrodder
youngrodder's Avatar
Great looking truck. Love the black Patina and door logo.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 10-07-2024, 01:27 PM   #709
6DoF
6DoF's Avatar
always good to keep it in the family! sweet truck to keep truckin
6DoF is offline   Reply With Quote
