Old 01-17-2018, 06:58 PM   #176
docrock
docrock's Avatar
Re: My 54 GMC Build
18 for the one tank I ran it. Probably could have got 22 if I wasn't flooring it everywhere
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344
1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494
R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438
1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250
docrock is offline   Reply With Quote
Old 01-20-2020, 08:04 PM   #177
docrock
docrock's Avatar
Re: My 54 GMC Build
I should have kept this truck. It sold again. I missed it on ebay in January. Love to see some pics of it out there somewhere
Old 04-21-2020, 09:35 AM   #178
JoeDude
Re: My 54 GMC Build
Originally Posted by docrock View Post
Attachment 597902
I stripped the cab down to bare metal and sprayed with epoxy primer. Not sure how long this project will take but I dont want to go back and resand surface rust
Do you know if the epoxy primer seals the rust like the stop-rust stuff that turns black?
Joe
54 Chevy 3100
JoeDude is offline   Reply With Quote
Old 04-21-2020, 11:02 AM   #179
docrock
docrock's Avatar
Re: My 54 GMC Build
The converter works great on turning rust to iron oxide. Then spray epoxy primer on top of that. Every attempt should be made to sand the metal with a course grit to get the best bite of the epoxy into the metal. Metal etch works great to for bonding to bare metal and then epoxy over that.
Old 06-13-2022, 08:50 PM   #180
docrock
docrock's Avatar
Re: My 54 GMC Build
I miss this truck. Any chance anyone has seen it?
Old 11-13-2024, 07:55 PM   #181
docrock
docrock's Avatar
Re: My 54 GMC Build
Has anyone seen my old project?
Old 11-14-2024, 11:12 AM   #182
dsraven
Re: My 54 GMC Build
you should build another one or buy one that is as close to "built like you want" and change a few things to get it like you want it. it seems, since there are no replies to your querry, that your old truck is under wraps somewhere.
Old Today, 02:00 PM   #183
docrock
docrock's Avatar
Re: My 54 GMC Build
I think you are right. I am working on another 42 right now but maybe later if I dont run out of gas
