#101 |
Active Member
![]() Join Date: Oct 2011
Re: 1968 redo
I got the floor and behind the cab sprayed the other day. You cannot tell in this pic but the steering column is a different shade of blue with metallic. Door panels and top of dash between pad and windshield will be this color as well.
Joey |
#102 |
Active Member
Re: 1968 redo
Working on the cracks in the steering wheel with epoxy.
Joey |
#103 |
Active Member
Re: 1968 redo
Turn signal switch replaced. Was a little bit of a booger getting it in. Had to refer to a few posts on here.
Joey |
#104 |
Active Member
Re: 1968 redo
I am in need of all of these little parts that are supposed to go inside the circle on the clutch rod. Its being held in there with a cotter pin currently. All of the parts disintegrated when they were removed.
Joey |
#105 |
Active Member
Re: 1968 redo
Working on the carb. It's a monojet. Removed and ready for disassembly and a good cleaning.
Joey |
#106 |
Active Member
Re: 1968 redo
Carb is torn down and cleaned up. I hope I can remember how to put this back together.
Joey |
#107 |
Active Member
Re: 1968 redo
It is raining here and 40 degrees. Ended the plans to paint the door panels and top of dash today. So, I started work on the manifolds. Broke a stud off the exhaust manifold and found a crack. I'm gonna be needing a new exhaust manifold.
Joey |
#108 |
Active Member
Re: 1968 redo
Anyone know why this hole was filled?
Joey |
