Old 09-23-2024, 09:24 PM   #301
62 Barnfind
62 Barnfind's Avatar
Re: 1962 chevy c10 update.
Had everything in place. Used a straight edge to mark where it would be flush with the frame rail. Then cut out 7/8 in out and welded together. It hard to do.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 09-24-2024, 10:04 AM   #302
rbruno68
Thanks. I think I may have seen that in another thread. If I ever do something different with my 62, I think I would rather do this then add the blocks under the mount on top of the frame.
Rob
rbruno68 is offline   Reply With Quote
Old 09-24-2024, 08:19 PM   #303
62 Barnfind
Rob
I didn’t like the look so I just modified it.
John Z
62 Barnfind
Old 09-25-2024, 02:44 AM   #304
Braunschweiger
A nice structure, I like it very much.
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 11-11-2024, 10:43 AM   #305
62 Barnfind
Attachment 2403979Engine almost complete. Just did the first start and fired right off with 60lbs of oil pressure. Still have a few things to button up like power steering lines and a small exhaust leak. I have the exhaust dumped right now u til I come up way to get it to the rear. I’m open to suggestions.
John Z
62 Barnfind
Old 11-19-2024, 08:29 PM   #306
62 Barnfind
Wheels came in today!
John Z
62 Barnfind
Old 11-19-2024, 09:07 PM   #307
350TacoZilla
Nice! that's always a good feeling opening up those box's. I'm personally not into the big wheel look but can still appreciate the truck, can't wait to see it sitting on it's rubber.
350TacoZilla is offline   Reply With Quote
Old 11-19-2024, 10:03 PM   #308
62 Barnfind
I can’t either! I think the rear is going to be tight. I had 15x8 all around and wanted to change the look a little bit
John Z
62 Barnfind
Old 11-23-2024, 08:49 PM   #309
62 Barnfind
Today I put the bed on to test the clearance on the wheels. It’s a little tight but it fits. I still think I need to roll the lip a little to get the extra 3/8 clearance.
John Z
62 Barnfind
Old 11-24-2024, 12:16 AM   #310
SkinnyG
SkinnyG's Avatar
How wide are those wheels?
I'm tucking a healthy amount of 17" rim, but they are only 7.5" wide. There sure isn't much room in the step side fenders.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 11-24-2024, 09:49 AM   #311
62 Barnfind
20x9 with 5in backspace. 1in on the inside and 3/4 on outside lip.
John Z
62 Barnfind
Old 11-30-2024, 11:00 AM   #312
62 Barnfind
Yesterday I went and had the tires installed. The rears fit but touched on the outside lip. I had to cut 1/4 off the fender lip to get the look I was going for. Not they have plenty of room. I did a test drive and this is a totally different truck!
John Z
62 Barnfind
Old 11-30-2024, 02:34 PM   #313
350TacoZilla
Looks good. I need to get one of those manual fender lip rollers sometime for stuff like that, they seem super useful but just don't need it very often.
Old 11-30-2024, 02:56 PM   #314
SkinnyG
SkinnyG's Avatar
I have a fender roller, but usually have better luck with a baseball bat or a piece of pipe.
You would need to be careful of the rods that help the fender keep its shape; the fender won't roll easily there. Because of the thickness of the metal, cutting is probably easiest.
Looks nice! (though... I want lower...(grin))
Old 11-30-2024, 07:57 PM   #315
62 Barnfind
I tried rolling it but did more pushing than bending. So I made a line where it was going to be folded and cut it out. Came out much better. My last wheels were 15x8 with 4in back space and it had about a playing card between the wheel and fender. I needed to do it then but never came around to doing it. The truck drives so much better with everything I did to it.
John Z
62 Barnfind
Old 12-14-2024, 11:49 AM   #316
62 Barnfind
Took my truck on a long drive yesterday to the alignment shop. It had plenty of passing power and the temp ran between 160-180. I decided that the exhaust is too loud for me. So I will be hunting for another set of muffles to quiet it down.
John Z
62 Barnfind
Old 02-17-2025, 10:28 AM   #317
62 Barnfind
Did a little more on the truck this weekend. I installed red inserts in the Bowie hubcaps. I think it give more of an original look. Also installed Dakota Digital gauges. Nice upgrade but a lot of work to install.
John Z
62 Barnfind
Old 02-17-2025, 01:48 PM   #318
Braunschweiger
A very nice truck, good work.
Greetings Harald
My 62 build thread
Old 02-17-2025, 04:19 PM   #319
62 Barnfind
Thanks!
John Z
62 Barnfind
