Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 05-21-2014, 05:29 PM   #1
briank
harbor freight 3 in 1 shear problem
I have a 40" harbor freight slip roll, brake and shear that has not been used much. Problem is when I went to shear a piece of sheetmetal...probably 18 or 20 ga the shear goes down,hits the metal and comes back up as I use the arm to make the cut. Anybody have problems with this before or have any suggestions?
briank is offline   Reply With Quote
Old 05-21-2014, 08:35 PM   #2
hotstuff
Re: harbor freight 3 in 1 shear problem
I had to adjust mine in , out of the box .
hotstuff is offline   Reply With Quote
Old 05-21-2014, 08:55 PM   #3
briank
What did you exactly adjust? I tightened the bolts that hold the cutter but that didnt help. Im overlooking something I'm sure.
Old 05-22-2014, 04:51 PM   #4
hotstuff
When you cycle , the blade should be below the the cut off edge all the way across . If yours was preassembled they may have the screwed up the cam and / or gear assy.
Old 07-12-2014, 05:48 PM   #5
briank
Finally took the time today to see what I could do to remedy the problem as I hardly ever use it but have begun making patch panels. The damn frame is completely broken on the right side so when when you pull the handle down to sheer, the whole thing separates.....,complete junk. Gotta love chinese steel. Ill have to see of I can find central machinerys phone number and see what they say. Harbor freight said 90 day warranty. Ive had it since April 2009 but hardly have used it and only on thin sheet metal. If I can't fix this its now a $600 boat anchor.
Old 07-14-2014, 08:58 AM   #6
magicoolbus
magicoolbus's Avatar
If H.F. still carries the exact same model, then buy a new one and return you old one for full price.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
Old 07-16-2014, 02:13 PM   #7
A1971Blazer
A1971Blazer's Avatar
Disassemble it and find a good welding shop. The cast iron frame can be tig welded back together with Ni99 nickel rod for a good strong weld.
A1971Blazer is offline   Reply With Quote
Old 07-22-2014, 11:46 AM   #8
briank
Well my buddy fixed it using the nickel rod, looks good. I have now reassembled it and bolted it to a steel table so it should hold up since it cannot move.
Old 07-22-2014, 09:00 PM   #9
briank
Well it broke again. Anynody know if I can get parts for this pig? I highly doubt I can buy the leg I need .
Old 07-22-2014, 09:27 PM   #10
franken
Just curious, did it break near the weld? Cast is hard to weld w/o a new failure due to the need to preheat.
I'm no welder, but I doubt you'll find much nickel in Asian cast iron.
Pics?
Maybe fab a new part, from sheet built up? Troll some fab sites for inspiration. Still, no way to get parts for what you don't fab
Old 07-27-2014, 12:03 PM   #11
briank
Contacted harbor freight for the right leg and low and behold its discontinued. I can get the left leg but thats not the weak side from what Ive read on various forums. It broke right at the weld, my buddy should have gussetted (sp?) it. Fabbing one is a tough job because of where the rollers slip in and the roller adjustment rod in the back.
Old 02-08-2025, 07:35 AM   #12
Preacher141
Am trying to figure this out myself. Will have to look if ours cracked. I was so pissed when it said 20 guage sheet metal max. So, my next thing is, I may just break it down into 3 tools if I can't figure it out. My dad has been a fabricator for 70 years. Most worthless tool I ever bought, period. Can barely shear of bend an aluminum license plate.
Preacher141 is offline   Reply With Quote
Old Yesterday, 02:36 AM   #13
MySons68C20
MySons68C20's Avatar
10 years later still a pos...
MySons68C20 is offline   Reply With Quote
Old Yesterday, 10:10 AM   #14
raggedjim
raggedjim's Avatar
I know it sounds janky but you can drill and tap some holes on both sides of the crack and then bolt on a flat piece of steel across the crack. We had a press in the machine shop on my first ship that had been repaired like that and it saw a lot of use.
raggedjim is offline   Reply With Quote
