Old 09-30-2016, 03:38 PM   #26
toddoky
Re: Dirty Dingo LS Low Mount A/C Bracket
Originally Posted by Hart_Rod View Post
I'm sure it will fit as the compressor is smaller than the factory one. Was really just wondering how the lines come off the compressor in relation to the frame. If you want to send me one, I'll do some R&D for you......
I'd love to send you one to test fit, but I unfortunately don't have any authority to do so. The best I'll be able to do to help in that regard is to post dimensions on it as we get closer to its release.
toddoky is offline   Reply With Quote
Old 09-30-2016, 03:43 PM   #27
Hart_Rod
Hart_Rod's Avatar
No worries, was just messing with you, .
Hart_Rod is offline   Reply With Quote
Old 10-03-2016, 12:10 AM   #28
shores6
shores6's Avatar
I've been looking at this mount. Was going to try to use it with my level 3 dropmember. Its kind of my last option. I can't put it up high because of my turbo. But down low is tight because of the pb motor mounts. Anyone used it with a dropmember yet?
Todd
https://www.instagram.com/shores6/
Project: Boosted Blucille. '70 C10 SWB PB Fab, LS2 S480 - http://67-72chevytrucks.com/vboard/s...d.php?t=700419
shores6 is offline   Reply With Quote
Old 10-03-2016, 10:16 AM   #29
knomadd
knomadd's Avatar
Since this thread is supposed to be about the Dirty Dingo mounts, here are some pics of that bracket installed into my 71 factory frame, factory cross member.
I'm using 45* EZ Clip fittings for the lines, in case anyone is wondering.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 10-03-2016, 10:41 AM   #30
Hart_Rod
Hart_Rod's Avatar
That looks good!
Old 10-03-2016, 11:21 AM   #31
toddoky
That DD mount seems to provide good fitment in your application...nice pics.
Old 01-12-2017, 11:23 AM   #32
PowerdbyChevy79
PowerdbyChevy79's Avatar
what headers are you using brother?
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 01-13-2017, 10:08 AM   #33
knomadd
knomadd's Avatar
Hey Ruben, I will be using Doug Thorley Tri-Ys, 324Y-C to be exact.
-Duane
Old 01-13-2017, 11:30 AM   #34
PowerdbyChevy79
thx for the info brother
1966 C10 "Mary"
Old 01-23-2017, 10:03 PM   #35
jessemthompson
I'm considering the Alan grove low bracket. I have a high mount kwik bracket right now and it throws the belt if I get on it. Everything's lined up, I think the tensioner isn't keeping things tight enough and it's brand new. I have ECE motor mounts, so I believe my sanden compressor will fit down there okay.
jessemthompson is online now   Reply With Quote
Old 01-24-2017, 01:42 AM   #36
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
So bottom line, will this bracket clear the frame with the mounts described?
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 01-24-2017, 10:37 AM   #37
knomadd
knomadd's Avatar
I don't see why it wouldn't. I don't have any experience with the Holley mounts, but I don't suppose they will raise or lower the engine much. If they raise the engine, it should be fine. If it lowers it, you'll possibly have other issues to work with too, like the oil pan.
-Duane
Old 01-25-2017, 12:40 AM   #38
1970 CST Short Wide
Senior Moment
Would you like to sell your Kwik set up??
Pittsburg Ca
94565
Old 08-18-2017, 05:13 PM   #39
Rsj4h
Anybody ever try the Dirty Dingo or Holley low mount on their 73-87 2wd C10 with the Holley mounts?
Rsj4h is offline   Reply With Quote
Old 12-31-2018, 07:53 PM   #40
Slowguy
Not to raise up an old thread, but I didn't see any resolution to this really. I need to keep my compressor in the stock location because I plan to have a passenger side log manifold style single turbo above. It seems the options appear to be:
1: keep the stock compressor with stock bracket and modify the frame to deal with refrigerant lines and compressor clearances. This will not allow the use of sliding engine mount brackets.
2: Dirty dingo bracket with small sanden compressor. This seems to be the best fitting option as the compressor is compact and very tight to the block. I have POL tubular perches and was going to buy a sliding "adjust2fit" bracket to go with the POL poly mounts I already have.
3: Alan grove bracket which will work, but uses a larger sanden compressor. Might be a tighter fit? May or may not work with adjustable engine mounts?
With the LQ4 LS gen3 truck engine, is it necessary that I need adjustable "sliding" engine brackets? I won't know this (unless someone chimes in) until I actually fit the engine in place.
It would be nice to get what I need so I don't have to mess around with dry fitting the cab just to see if the block will clear the firewall etc. It is so much nicer to mount all the brake lines, fuel lines, air ride lines, wiring, etc, without the cab in place. I'll take more time and it'll be a much prettier result without the cab set in place.
Slowguy is offline   Reply With Quote
Old 12-31-2018, 08:39 PM   #41
Rsj4h
Yeah I ended up going with the Dirty Dingo mount and small Sanden compressor, worked out perfectly!
Old 12-31-2018, 09:28 PM   #42
Slowguy
did you need or use adjustable engine mounts to slide the engine forward or backward for clearances to the cab/firewall?
Old 01-03-2019, 11:26 PM   #43
knomadd
knomadd's Avatar
I did not buy the slider kind of adapters, but I did have the adjustable kind (3 different motor mount positions). The sliders would have potentially been easier to get the engine in the right spot, but I did move them and the engine perches about 4 times to get the cab and crossmember clearances just right. There is absolutely NO WAY I'd try to get the engine mounted and "set" without at least checking the firewall clearance. There isn't a lot of movement front to back to fit between the firewall, radiator and crossmember.
-Duane
Old 01-27-2019, 05:15 PM   #44
Slowguy
Finally came in and got it installed. Looks like it may work. Fits nicely. I’ll know more when I get the engine installed on the frame.
Old 12-18-2019, 02:58 AM   #45
Ford Assassin
Ford Assassin's Avatar
Digging up an old post yet again....
I am curious and concerned on how well a mini Sanden would preform on an otherwise stock AC system on a crew cab squarebody. Old Air suggested a Sanden 709 to replace the HR6 (A6 style) compressor.
I too am going to run a turbo LS setup like the rest of my rides.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 02-08-2025, 09:56 PM   #46
UniqueOdyssey68
UniqueOdyssey68's Avatar
Reviving this thread...anyone else used this recently? I'm looking at using this really soon. Hoping it will fit my 2006 5.3 L33 block and clear the 68 frame well in the space..
I was advised that using this kit and smaller SD7B10 compressor requires custom lines to be made, the lines that come with the vintage air kit can't be used. ? Anyone know why that might be?
https://www.dirtydingo.com/shop/prod...oducts_id=1756
- long term project '68 C10 true shortbed! Resto-mod. LS swap. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=769919 "I've still kept this project truck when anyone else would've given up and sold it as is. Giving up is easy, staying the course is part of life's journey"
___________________________________________
'68 C10 true shortbed, LS swap restomod. '03 Z71 daily, '63 AMC Rambler V8 survivor
UniqueOdyssey68 is offline   Reply With Quote
