Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 03-13-2022, 11:08 AM   #51
jjzepplin
jjzepplin's Avatar
Re: New 2 ME 14 Sierra SWB 5.3-6spd Hope I didn't blow it...
I am kinda on the fence with the header install. I guess I will tune it first and then make a decision. I am glad the broken bolt is out though. I could not hear an exhaust leak but when I got the manifold off it was clear there was a leak and it no longer stutters upon hard acceleration with the stock manifolds reinstalled. I tested it that way before doing the headers to make sure whatever went wrong was not the headers.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 03-13-2022, 12:31 PM   #52
jjzepplin
jjzepplin's Avatar
Does anyone have anything bad to say about E3 spark plugs? I got a set for Xmas and want to install them here but I am thinking I will do this when I tune it. Oh and here she is lowered.
Old 03-14-2022, 06:47 AM   #53
biketopia
Looks good, glad you got it knocked out!
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 03-20-2022, 08:58 AM   #54
jjzepplin
jjzepplin's Avatar
Thanks! The front tires rub just a little during full hard turns and I felt a little powering through a turn as I punched it. Might have to go down a size or two. I definitely don't want super thin rubber. It's louder than I would like right when I start it but I think that might be the VVT on the cam. About ten seconds and it quiets down.
Old 10-03-2022, 01:34 AM   #55
jjzepplin
jjzepplin's Avatar
Well I been struggling with getting the cruise control to work again on this thing and some say it is most likely the brake light switch. There are a couple different ones and the one I pulled out was not the same as the one I bought for the 2014. I guess mine is actually a 2015ish model because that switch matches numbers correctly. A SERIOUS pain to replace though! This will be third time. UGH!
Old 11-24-2022, 02:53 PM   #56
MiniD
Brake light switch is possible but make sure all of your brake lights (including center) are working, first. Also... LED brake light bulbs with no resistors are infamous for causing cruise control not to work.
That's a nice looking truck. Great catch on the standard cab SWB. I'm going to be doing much of the same to my 2012 quad SWB next year.
MiniD is offline   Reply With Quote
Old 11-25-2022, 07:54 AM   #57
jjzepplin
jjzepplin's Avatar
Oh my. Thank you for the heads up. I have not tried this new switch yet but it was only $10. I also am going to tune this truck soon. I saw a great video on tuning the transmission. I also want to disable cylinder disable function. I think it is messing with my shifting.
Old 11-28-2022, 08:20 AM   #58
jjzepplin
jjzepplin's Avatar
Well I did have a third brake light out. Incandescent bulb though. Replaced it and nothing but a working brake light. My engine light is on from the header install so maybe that's it.
Old 11-29-2022, 12:08 PM   #59
jjzepplin
jjzepplin's Avatar
Well it was NOT the brake light switch. $10 down the tubes. I am thinking maybe the clocking ring or actual switch that turns the cruise control on? Boggling.
Old 11-30-2022, 09:06 AM   #60
biketopia
Most likely it's because the check engine light is on. You'll need to tune out the codes for cruise to work properly again. Are there any other codes in memory or lights on?
Old 11-30-2022, 04:49 PM   #61
jjzepplin
jjzepplin's Avatar
Well I cleared al the codes and still nothing. I just know it is something easy...
Old Today, 04:35 AM   #62
LT7A
Still got this rig? Looks sharp. The lowering kit came out just right. It's gotta be fun to drive.
