Old 05-21-2024, 11:50 AM   #26
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: overheating at idle
You either have worn engine mounts, or the core support bushings are incorrect.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
1970cstblazer is online now   Reply With Quote
Old 05-21-2024, 12:32 PM   #27
vardenafil
how do i tell if my engine mounts are bad? or if my core supports are wrong?
vardenafil is offline   Reply With Quote
Old 05-23-2024, 06:58 PM   #28
joeydurango
joeydurango's Avatar
Yes, as has been said, the K truck engines sit back further than the C trucks. I believe this is to keep the oilpan from contacting the front axle/diff. My K10 has the stock engine location, deep shroud, aftermarket clutch fan that I installed, and a fan spacer that moves the fan into the proper space within the shroud.
Just a little more info for you, hope it helps!
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
Old 05-23-2024, 07:00 PM   #29
joeydurango
It could also be that the shroud isn't installed properly at the bottom. Take a look, it's easy to check. Is it firmly seated to the bottom of the clips that hold it in place? If someone got frustrated and didn't install it properly, it could rotate the bottom back toward the engine, lifting the bottom of the shroud toward the fan.
Old 05-25-2024, 04:38 PM   #30
vardenafil
somehow i missed the passengers radiator mount bushing is loose. I ordered new bushings to see if it will settle.
