250 air cleaner
All,
I upgraded to a 11" brake booster when adding disc brakes and original air cleaner no longer fits on the monojet single barrel carb. What is best solution? With tighter clearance it seems a 8-9" air cleaner is as large as I can go. The carb has a manual choke so I need to figure out about a 1" rise as well. Any direction would be appreciated. |
Re: 250 air cleaner
Re: 250 air cleaner
Safety concern for you.
Move or eliminate that fuel filter. They tend to crack and leak. Not a good spot over the exhaust. |
Who Changed This?
![]() Join Date: Jan 2013
Re: 250 air cleaner
^ Indeed. I had one of those on my '66 Le Mans that was dripping on the intake manifold exhaust crossover. Crazy. I'm actually considering replacing the fuel filter on my truck with something like the inline filter that the general put between the tank and the fuel pump.
Re: 250 air cleaner
If you’re not worried about originality try a search on mini air filters found this real quick . And ditch that filter asap they tend to leak .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
Re: 250 air cleaner
Re: 250 air cleaner
The right design but not sure on the riser fitting onto the carb.
Might need an adaptor for that. |
Re: 250 air cleaner
I wouldn't wish one of those little tiny air cleaners on anyone.
With a Clifford Intake and a 4bbl you need even more room. I used a booster without the bell crank to move the MC farther away from the engine. I used the original '67 offset air cleaner, but welded on a much larger throat for the Carter AVS and enlarged the passage way across the top, to prevent restriction. Originally, I kept it as a oil bath, but could never keep it clean. I gutted the inside and converted it to use a paper filter. That vent tube on the top of your carb is for a Charcoal Canister. Not sure what you have under that tape, but the float bowl needs to be able to breath so you can't close it off completely. I cut the conical center out of a Rochester stone filter and jammed into the vent tube on my Carter. Every couple of years I pull it out and clean it. I'd rethink that manual choke, cable holder. The original holder would have been similar to this one that Edelbrock sells. It could be trimmed and maybe even a new hole drilled to make it more compact and probably more reliable. It uses one of the carb top screws.
'67 GMC 2500, 292, 4spd, AC Last edited by RichardJ; 06-08-2024 at 12:58 PM. |
Re: 250 air cleaner
I bought this from Speedway for $20, maybe less. Used a longer bolt for the stud as stock was too short. Manual choke. Has a punch out in bottom for breather hose
#10 | |
![]() Join Date: Feb 2002
Re: 250 air cleaner
I crossed over into the 4 Barrel camp in 1978, so I can't help the OP's quest for an aftermarket Monojet air cleaner.
![]() Join Date: Dec 1999
Re: 250 air cleaner
Here's one I have where a previous owner chopped a chunk out and flipped it around(and welded it back in) and then trimmed the top. I cleaned up the work some and have been happy enough with it.
#12 | |
![]() Join Date: Jun 2005
Re: 250 air cleaner
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#13 | |
Re: 250 air cleaner
![]() BTW, your inbox is full. |
Re: 250 air cleaner
It is a 1968, daily drove it for about a month over the winter. It's much dirtier than that now, but that photo was right after putting it back together.
#15 |
Re: 250 air cleaner
Congratulations that is one awesome looking engine compartment ! The attention to detail is incredible..Jack
71 C-20 07 Magnum RT AWD |
#16 |
Re: 250 air cleaner
I need an updated picture but couldn't find one. Got a longer Positive battery cable so it's not just draped over the inner fender and replaced the 3/4 ton booster and MC with aftermarket.
