Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 06-09-2024, 01:02 PM   #1
Lost in the 60's
Active Member
Lost in the 60's's Avatar
1989 C30, power window circuit breaker location
I need to try replacing this to get my windows to work, but haven't found any useful info about where it is located on the truck. All help appreciated.
Mitch
Lost in the 60's is offline   Reply With Quote
Old 06-14-2024, 10:11 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: 1989 C30, power window circuit breaker location
Here's a copy/ paste from co-pilot.
The power windows in your 1989 C30 don’t use a fuse; instead, they rely on a circuit breaker due to the high draw of the window motors. The circuit breaker for the power windows is labeled as #47, and it can be found in the smart box or under the hood fuse box1. Unfortunately, the 30 amp breaker cannot be reset; if it’s faulty, it needs to be replaced. If a new one also pops, there might be a short to ground in the power window circuit. Additionally, check the blu/black power wire coming from the rubber boot in the door, as it’s a known issue in the 2003 Ford Explorer2. Hopefully, this information helps you troubleshoot the issue with your power windows! 😊
Hope this helps.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
