Old 07-06-2024, 06:00 PM   #1
J_T
Question Question How are hickey fuel tanks mounted?
Hello all, I was changing my body mounts But I found that the hickey fuel tank mounts under the frame into the tub. So therefore I can't raise the rear of the tub to swap the body mounts. I believe this tank has through bolts. Is anyone familiar with The type of hardware that is on the underside of the through bolts? It appears to be a flush mount nut but uses a square head? Either way, mine are rusted on and I thought about just grinding off the heads in the tub and dropping everything down But I wanted to confirm that would actually be enough to drop the tank?
Thank you all!!
J_T is offline   Reply With Quote
Old 07-06-2024, 09:23 PM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Question How are hickey fuel tanks mounted?
I’m not certain, but maybe these tanks were mounted in a manner similar to the auxiliary pickup tanks with example hardware seen here: https://www.67-72chevytrucks.com/vbo...d.php?t=734283
Old 07-06-2024, 10:51 PM   #3
J_T
Here are some pics i finally figured out how to share. It appears these are threaded internally and use a square drive? I tried to spray pb blaster inside which is why they look wet
Old 07-07-2024, 07:05 AM   #4
1970cstblazer
1970cstblazer's Avatar
Arrow Re: Question How are hickey fuel tanks mounted?
That sure does look like how the pickup RPO NL2 auxiliary tank was mounted..
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 07-07-2024, 09:09 AM   #5
J_T
Awesome! Thanks I'll weld some nuts to the bottom and be gentle with it. The square holes were deforming.
