Old 07-06-2024, 07:23 PM   #1
1project2many
Radio project
Many years ago, probably around 96, I started on a project to install the electronics from a late model radio into an oem '57 housing. It took me a long time to finish up and when I got done something didn't work so I put it in a box for later. It's later.
This uses a stock head unit from a '98 Suburban as the donor. All of the original functions still work. And if for some reason I wanted to put an OE CD player under the dash, I could connect it to the head unit and it would operate properly.
I realize this project isn't for most people. I did it for the challenge, and because I wanted to finish what I started. I Plan to use an original speaker grill over the mirror with two small speakers in it. There are some pretty neat under seat speakers that are self-contained that might sound good. I'm also considering building fuel tank cover speaker box, and storage tray behind the seat.
I really excited about this and I can't wait to get it installed in the truck to see what it looks like.
1project2many is offline   Reply With Quote
Old 07-06-2024, 07:39 PM   #2
autowrench
Re: Radio project
I love the concept! Thanks for sticking with it and giving the rest of us an idea to try. Keep us in the loop please!
autowrench is offline   Reply With Quote
Old 07-06-2024, 09:22 PM   #3
fauXGT
fauXGT's Avatar
Re: Radio project
Are you my brother from another mother?
I live for this kind of thing. Taking something that appears old and stock but updating it and making it work.
I found a non-functioning 1950s Johnson Viking Messenger One 5 channel cb radio. Gutted most of the inside saving the vacuum tube plugs. Found a 1976 Midland 23 ch cb that I wired into the lower body. Set white LEDs with different color filters (yellow, orange...and different combos) into the center of the tube sockets. Wired the old mic with new internals. Left the ginormous and heavy transformer inside for effect. Fully functional. Turn it on and the tubes glow. It took about 2 months of winter weekends to finish.
Keep up the great work!
Chip
'51 Chevy 3600 5 window
C4 Vette front/rear suspension & drive train
full Rusto-Mod
'92 GMC Sonoma GT VIN #0015
'91 GMC Sonoma GT extended cab 1 of 1
fauXGT is offline   Reply With Quote
Old 07-06-2024, 09:32 PM   #4
fauXGT
fauXGT's Avatar
Re: Radio project
Oh, and you could look for a dual voice coil speaker for up above. One main woofer speaker and two tweeters. You get the stereo effect, but a deeper lower end freqs than 2 tinier full range speakers.
This is what I got for the 51 dash.
Chip
full Rusto-Mod
Old 07-07-2024, 11:53 PM   #5
1project2many
Re: Radio project
Thanks! I'm installing it now. the wiring under the dash is a mess so I'm cleaning it up. The original installation instructions for most accessories said to install them without fuses. We definitely need fuses.
Old 07-07-2024, 11:59 PM   #6
1project2many
Re: Radio project
That CB is awesome!!! Thanks for posting pictures. Using LED's to simulate the glow of the old vacuum tube heaters is over the top. Very kewl!
Thanks for the speaker tip. I'll look at speaker options again. I like the idea of a dual voice coil front speaker. I'm probably going to get sucked into a rabbit hole when it comes to rear speaker choices. No worries...
If I can put something together that can play Pink Floyd's "Meddle" well enough to inspire the next generation then I've done something right.
Old 07-08-2024, 11:06 AM   #7
JDarby
Active Member
Re: Radio project
Yes, This is right in my wheel house too!
40 yrs in the electronics business, I have swagged lots of solder
I would love too find a radio for my 55.1 GMC that I could do the same concept too!!!
Please keep us posted!!
1955.1 GMC 100 RestOMod
1972 T120RV
1967 C200 Trail 90
2014 TRD Quad CAB
JDarby is offline   Reply With Quote
Old 07-10-2024, 11:13 AM   #8
1project2many
Re: Radio project
I enjoy it as a hobby but it probably not as much fun if you do it every day. I have to wear reading glasses and 8X magnifiers to see what I'm working on.
OE radios can't be easy to find. There are reproduction units for big $$. Maybe it's possible to get someone to sell an empty repro case?
Old 07-10-2024, 12:41 PM   #9
1project2many
Re: Radio project
Update time. Before installing the radio I rewired the original fuse panel and some of the accessories. Much of the original wiring was direct from power source to load with no fuses. We now have fused power on both battery and ignition circuits. For anyone looking, the terminals used for much of the original wiring were known as Packard 56 series. They are now known as Aptiv 56 series. The best pricing I've found for the terminals and plastic holders is from Waytek Wiring.
I ended up raiding old wiring harnesses to get correct color and gauge wiring for the later GM radio harness. I realize GM speaker wiring isn't the best. The antenna coax and speaker wiring are all routed through the RH A pillar where clearance is limited.
I'm using this antenna:
I wanted to put it between inner and outer panels at the dome light but it just couldn't pick up any stations there. It's at the top center of the rear window. The cable is about 6mm OD which isn't too large, but the plug for the radio is too big to fit through the ceiling. So I ended up removing the plug and installing it after the coax was properly routed. This is always fun. Luckily this one uses plastic and rubber so it's fairly easy to take apart and reassemble. One tip for this work is to buy a coaxial cable stripper. It really makes this work easier.
I'm also using a signal amplifier:
The booster is located near the glovebox
and I'm using the power antenna trigger to supply power to the booster.
Routing wires through the ceiling was an exercise. Welding wire and mechanic's wire kept getting hung up. The best tools I found were actual cables. I used a bicycle shifter cable and a length of 1/8" cable to feed through the panels. It was also incredibly helpful for an assistant to pull cable while I guided it at the other end. This was especially helpful guiding wires for front and rear speakers through the A pillar.
Using original instructions for the speaker I was able to recreate a template to mark the ceiling. 2"screws are the minimum length required to attach the enclosure. The enclosure is not quite 5X8 so I'm awaiting this pair of 3.5" speakers.
I'm still working out whether or not I should cut holes in the ceiling for clearance like OE. The original instructions called for 3.5" holes for clearance. If I need to cut the ceiling these magnets are just over 3".
Old 07-10-2024, 01:04 PM   #10
leegreen
Re: Radio project
I have the same antenna stuck vertically on inside / side of rear window, with an extension cable but no amp. It works well for FM but zero AM. My amazon no name head unit is supposed to have AM, at this point I am not sure if it is the antenna or if the AM band on the head unit is just for marketing purposes. I'd be curious if you get AM through that antenna.
(yeah AM is almost dead but still good news and traffic locally)
TF A pillars do look a lot harder to fish than AD!
Leave yourself a permanent pull string, I'm glad I did as I have added wires to overhead console twice since I thought I was done pulling wire.
leegreen is offline   Reply With Quote
Old 07-10-2024, 01:39 PM   #11
Hcb3200
Re: Radio project
PULL STRING in Task Force Piller where the heck were you 5 years ago. that will be going in the next time I am wiring something.
Hcb3200 is offline   Reply With Quote
Old 07-11-2024, 12:12 PM   #12
57tailgater
Re: Radio project
Hey 1project2many I really like this thread. Anxiously awaiting to see if you have to drill the holes for speaker magnet clearance. I am wanting to do a similar thing but don't want to cut the cab if I don't have to. It looks like you used some welting/edging on the speaker box where it meets the cab. What did you use? Looks very good.
57tailgater is offline   Reply With Quote
Old 07-11-2024, 01:22 PM   #13
1project2many
Re: Radio project
I will check and let you know.
Yes! I will definitely leave one in there. The real trick is remembering to pull the next pull string through before you pull the current one all the way out!
Thanks!
The speakers haven't come in yet but by the numbers I'm going to have to do something to add clearance.
Thanks! It's generic black vinyl door edge molding. I left it in the sun to soften up. One strip is enough.
