![]() Join Date: Jul 2015
Body mounting hardware
So I'm hoping to get around to mounting my cab and core support to my chassis in the coming weeks. I'm digging through my parts stash of new and used stuff. I'm planning to install these bushings, https://static.atechmotorsports.com/.../ens-17016.pdf I can source new bolts locally and have the specs on them, but I can't seem to locate the factory washers it speaks of in the directions. Are they just a thick washer or do I need the specific factory style ones and are they available anywhere?
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
#2 | |
The Older Generation
Re: Body mounting hardware
The body mount washers are close to the same diameter as the bushings they fit against and are approx. 1/8" thick. The core support washers are thinner but still thicker than most hardware store washers. Try ACE Hardware, Fastenall, (if you have one in your area), or as last resort a farm store. (check in the farm equipment area of the store for the bigger washers) .
![]() Join Date: Feb 2022
Are you sure you want urethane bushings?
Different is not always better. |
![]() Join Date: Nov 2018
#5 | ||
Junior Member
![]() Join Date: Apr 2021
Front cab or radiator support location? It's a square washer with a square hole because the radiator support body mount uses a carriage bolt. It restrains it from turning while the nut is tightened. You could access a hex head bolt with some long extensions, then you wouldn't need a square washer with a square hole. I don't recall there being a square hole washer at either cab mount location.
The instructions indicate front cab, but makes a lot of sense for the radiator support though.
