Old 08-06-2024, 04:00 PM   #1
straight6chevyguy
straight6chevyguy's Avatar
Speedometer problems with my 76
Hi everyone so this last Sunday I took my 76 C10 for its first trip to town in something like 18 years the drive went great accept my speedometer wasn't working correctly.
It seems to work ok at lower speeds but once you get to about 45 it seems to want to move around and I can't seem to get it to go above 50.
I removed the cable and lubed it and it seemed to turn smoothly but it made no difference one re installed. Anyone have any suggestions on what to check next?
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 chevy c20 350 4speed
1998 chevy c1500 4.3L 5speed
2002 Chevy s10 4.3L auto 4x4
Plus a Mercury & some Fords... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 08-06-2024, 04:38 PM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: Speedometer problems with my 76
Did the cable seat in the cluster properly, I.e.: pushed in until it clicked?
Old 08-07-2024, 01:28 PM   #3
straight6chevyguy
Yes, It is snapped in all the way as far as I can tell.
I checked it more than once just to be sure.
So after driving some more I have been able to get it above 50 but it's pretty bouncy it seems maybe it's reading something like 5 to 8 mph slow but it's accuracy seems to depend on what speed I'm driving. I also have noticed a "snapping sound" come from the speedo gauge on occasion seems like I noticed around 35 to 40 mph when I hear the snap my gauge needle will jump.
Im kinda thinking there's something wrong with my speedometer gauge?
What do you guys think?
Old 08-07-2024, 03:40 PM   #4
Dead Parrot
A 48 year old mechanical device may need replacement or a bunch of TLC. Sadly, not many old school speedometer shops left.
The speedo in my 75 is also bouncy but is better at higher speeds. The odometer is on its 3rd cycle through the numbers. The bounciness has survived a couple of replacement cables. Pretty certain at this point it is the gauge.
Dead Parrot is offline   Reply With Quote
Old 08-11-2024, 03:00 PM   #5
72malibu
Active Member
72malibu's Avatar
On the 75 I'm working on, the cluster is out for freshening up. I cleaned and lubed the old cable, connected it to the gauge, inserted the other end into a cordless drill, and spun it to check for smoothness. The needle fluctuated. So, I bought a new cable and tested it - no fluctuation. Maybe try a new cable.
72malibu is offline   Reply With Quote
Old 08-17-2024, 12:54 PM   #6
straight6chevyguy
Thanks, I will probably try a new cable before changing out the gauge.
Old 08-18-2024, 09:55 PM   #7
wbort27
Mine was doing same thing had to replace gauge on my 75 good luck
wbort27 is offline   Reply With Quote
