![]() Join Date: Apr 2016
Ignition lock assembly
I will start another thread to maybe get the lock cylinder figured out, so I won't pollute the Making Keys For The ’60 -‘66 Chevy Trucks thread too much.
Here's the story. LockDoc made keys for me so I could release the cylinder from the ignition lock. I've got it apart and cleaned up. I can't figure out how to get it back together. This is on my 1963 C10. While trying to figure it out I tried to find out the names of the parts by searching the www but I may not be good at that. So here I'm giving the parts these names. If there's better or more official names I would like to know, and I'll edit my post. 1 cylinder keeper slot 2 spring cover 3 latch 4 pin release hole 5 pin block 6 cylinder keeper 7 latch up positions Pictures Last edited by dmjlambert; Today at 10:15 PM. |
Re: Ignition lock assembly
More pictures
More pictures
My observations
I think I'm showing the incorrect orientation of the pin in the first 2 pictures, because when inserted this way the pin pushes down but it sticks in the down position. In pictures 3 and 4 I inserted it the other way and it presses in and springs up. I don't know for fact the orientation because after I removed the cylinder I touched the pin and it popped out and onto the floor of the truck. Cylinder keeper 6 appears to keep the cylinder in the assembly in all normal positions of the key. Push the pin through the pin release hole 4 in order for the pin to clear the pin block 5 to move the cylinder keeper 6 into the cylinder keeper slot 1 and that allows the cylinder to release and come out of the assembly. I have noticed the latch 3 is depressed when the key is inserted, and the latch sticks out when the key is removed. The key can only be removed if the latch is not being held in. So areas in the assembly that are the latch up positions 7 are places where the latch is free to move up and therefore those should be where the key can be removed. The spring cover 2 does not move, it is swaged into place. So here is my problem. When I put the cylinder back in the assembly and it snaps into place, I can depress the pin through the hole and turn the key to the right and it moves through the off, on, and start positions. In the start position the key will tend to spring back to the on position. All good so far. If I turn the key to the left, it sticks in that position forever, unless I depress the pin through the hole again. Then I can turn the key again. |
Tags |
lock cylinder |
