Old 10-30-2024, 01:08 PM   #1
72malibu
Active Member
72malibu's Avatar
15x10 Rally Wheel - Fitment?
I want to put 15x10s on the rear of a 75 C10, no suspension mods.
What backspace should I be looking for, for the best look and fitment?
(I'm planning to use a pair of NOS 15x8s in the front, 4.5 backspace).
72malibu is offline   Reply With Quote
Old 10-30-2024, 02:54 PM   #2
Wikid61
Wikid61's Avatar
Re: 15x10 Rally Wheel - Fitment?
Several sizes. You can bolt the stock 8" on the rear & measure how far inboard you can go, 2". Or go inboard 1" & outward 1 inch. Is 15x10 the only option? Going in 1.5 inch & out 1.5 for a 15x11.
"Envy is a declaration of inferiority". Napoleon Bonaparte.
Wikid61 is offline   Reply With Quote
Old 10-30-2024, 07:27 PM   #3
Loco83
Loco83's Avatar
I'm running 15x10 Rallys on the back of my 83 with a 5" BS and 295/50 TA's, no rubbing, also 15x8 on the front with 4" BS.
Loco83 is offline   Reply With Quote
Old 10-31-2024, 11:04 AM   #4
72malibu
Active Member
72malibu's Avatar
Thanks. I think all the OEM 15x8 truck rally wheels were 4.5 backspace if I'm not mistaken. I'm just going to use a pair of those for the front, probably with 245/60 tires.
The 15x10 is obviously custom. I've seen used pairs with 4.5 backspace but I know that Wheel Vintiques used to sell them with 5 backspace too. I'm looking at a pair of used 15x10s this weekend and will check the backspacing on them. I think if they are either 4.5 or 5 backspace they should work, especially since this truck isn't lowered. Probably with 295/50 tires. That should result in the same sidewall height and bulge front and rear.
Old 10-31-2024, 12:50 PM   #5
Loco83
Loco83's Avatar
Agree, I'm also running a 245/60 TA on the front.
Old 10-31-2024, 01:05 PM   #6
72malibu
Active Member
72malibu's Avatar
Looks perfect!
Old 10-31-2024, 02:06 PM   #7
Loco83
Loco83's Avatar
Another view from the front.
Old 10-31-2024, 02:27 PM   #8
72malibu
Active Member
72malibu's Avatar
Where did you get your trim rings? Those are the style I'm planning to use.
Old 10-31-2024, 02:50 PM   #9
Loco83
Loco83's Avatar
I ordered my whole tire and rim pkg from Jegs, I like the look of the narrow trim rings.
https://www.jegs.com/i/JEGS/555/681501/10002/-1
Old 10-31-2024, 06:02 PM   #10
3drburb
245/60/15 on 15x8 and 295/50/15 on 15x10 will be to short on a truck that is not lowered a lot.
3drburb is offline   Reply With Quote
Old 10-31-2024, 08:52 PM   #11
72malibu
Active Member
72malibu's Avatar
Well that's a good point. This one isn't going to get lowered, at least not anytime soon.
The 295/50/15 are 26.7" tall. I probably should be looking at a 28" tire, right?
I don't think there are many (any?) good options for a 295/55 or 295/60 tire.
Maybe I ought to be looking at 15x8 in the rear with 275/60 tires (28") and something narrower but as tall in the front.
Old 10-31-2024, 11:38 PM   #12
3drburb
Yes, I wouldn't go shorter than 28" at stock height, also the 15x8 all around with the same tire size so you can rotate them.
There may be a thread on here with 15" wheels and tires sizes to help give you a better visual.
Old 11-01-2024, 08:58 AM   #13
72malibu
Active Member
72malibu's Avatar
I'm not worried at all about rotating - I'm restoring the truck for my 85-year old father and it won't be a daily driver. I've got staggered wheels on my own Chevelle for the look.
I'd like to go as wide as I reasonably can in the rear, which I think would be a 275 on an 8" wheel without looking too bulgy. I don't think there's clearance in the front for that with a factory 4.5 backspace on an 8" wheel but could be wrong. Guessing a 245 is in the ballpark. Will look at some other threads.
Old 11-01-2024, 09:30 AM   #14
3drburb
Got it.
255/60/15 front and 275/ 60 rear should be taller on 15x8 all around, just another choice.
Btw, what is the stock height ground to fender lip on a Square?
Old 11-01-2024, 10:04 AM   #15
72malibu
Active Member
72malibu's Avatar
I'm doing a long bed (Gentleman Jim) like the one pictured below.
I'm thinking 255/70/15 (first truck) or 275/60/15 (second truck)
Old 11-01-2024, 04:59 PM   #16
Loco83
Loco83's Avatar
[QUOTE=3drburb;9350741]Got it.
This would be my choice if running 15x8's all around.
Old 11-07-2024, 11:47 AM   #17
Hart_Rod
Hart_Rod's Avatar
15x10, 5" bs...
Hart_Rod is offline   Reply With Quote
