Old 10-31-2024, 09:23 PM   #1
Dude68
Active Member
Carpet
Looking for input on what needs to go between cab floor and carpet.
Joey
Dude68 is offline   Reply With Quote
Old 10-31-2024, 09:28 PM   #2
72c20customcamper
72c20customcamper's Avatar
Re: Carpet
Depends on what you are looking for . Super insulated and quite you need some floor mat or lizard skin . I bought the ACC with mass backing and that’s all I did . It’s a big improvement over just jute backing .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 11-01-2024, 07:22 AM   #3
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Carpet
I'm a Dynamat believer. This one improvement totally changed the driving experience, It is not cheap, but does so much to lower heat and noise into the cabin.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 11-01-2024, 02:13 PM   #4
samkost
samkost's Avatar
Re: Carpet
Yep, I’m happy I went with DynaMat also.
I also agree with 72c20customcamper
I used DynaMat for heat/sound insulation under a ACC mass backed carpet.
Sam
1972 C10 LWB
2020 Z71 Tahoe
samkost is offline   Reply With Quote
Old 11-01-2024, 04:11 PM   #5
71longbed-brew
71longbed-brew's Avatar
Re: Carpet
Kilmat 80 mil thickness
350/th350
DNA (Chinesium) Heads
Performer Intake
1905 AVS2 Edelbrock
3.42 Eaton Posi
71longbed-brew is offline   Reply With Quote
Old 11-01-2024, 06:37 PM   #6
LS short box
Re: Carpet
I used Dyna Mat like generic from Summit. I cut it to fit as needed. Then 3/8" double sided foil with jute in between the foil. Then standard carpet.
Old 11-01-2024, 11:28 PM   #7
Dude68
Active Member
Re: Carpet
Now that is why I am a member of this forum!!! I got several opinions on what works because it worked for them!!!
Joey
