12-18-2024, 09:59 PM | #1 |
72 c10 Alternator Wiring Harness Clip Retainer
Hi am looking for the following alternator Wiring harness retainer, along with mounting bolt and if there is a spacer or washer under the retainer. Like the set up in the picture.
Thanks |
12-22-2024, 04:07 PM | #2 |
Always on the hunt...
Re: 72 c10 Alternator Wiring Harness Clip Retainer
After a bit of digging around we ended up finding an OE 1972 p/n 1102455 alternator stored on the shelf, the alternator still had the below pictured 72 specific wire harness retainer bracket and mounting bolt attached. There is no spacer needed as the 72 style harness bracket mounts directly to a threaded standoff boss w/machined flat on rear of alternator, the smaller 71 and prior style alternator wire harness retainer bracket mounted to the ground stud on the rear of alternator, this grounding stud is not used/found on the 72 style 42 amp p/n 1102459 or 61 amp p/n 1102455 alternators. We have listed both the 72 harness bracket and alternator separately in the below linked f/s thread and given you first option/right of refusal, have a look and confirm in thread. Thanks for your patience in standing by while we dug this one up, Mel
http://67-72chevytrucks.com/vboard/s...d.php?t=856155 .
***For any return/past customers & friends*** Before sending of any funds, please wait for a confirmed total and instructions for sending as our payment account info has been changed as of Jan. 2023. Thanks... |
12-22-2024, 04:09 PM | #3 |
More pics...
12-22-2024, 04:11 PM | #4 |
More info/pics...
12-22-2024, 05:58 PM | #5 |
Hi Mel, that is the bracket and bolt I need, And yes I will take it.
Thanks Eddie |
