Old Today, 11:20 AM   #1
72malibu
Active Member
72malibu's Avatar
Engine Harness Routing Question
Working on a 75 but it should be the same for various years.
Does the fuel tank sending unit wire (tan with a boot on the end) route through the metal starter wire tube along with the starter wires, and then back to the tank, or does it not go into that tube?
For the life of me, I can't find any internet photos showing it.
72malibu is offline   Reply With Quote
Old Today, 03:04 PM   #2
Pontiac1976
Pontiac1976's Avatar
Re: Engine Harness Routing Question
no.
Should come out of the back side of the trans near the dist T down the right, frame to tank .
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old Today, 05:03 PM   #3
cadillac_al
Mine goes through the tube. It seems to work out well. I don't know if I would have thought of that myself and I usually like to leave stuff the way the factory did it. I have replaced the engine and trans in my truck though.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old Today, 05:43 PM   #4
72malibu
Active Member
72malibu's Avatar
I've got a new M&H harness. They make them just like the factory did.
The sending unit wire comes out the end of the plastic split loom with the starter wires. The split loom is taped around the end. The split loom is snug against the opening of the steel tube. So, if I leave the sending unit wire out of the steel tube, it's going to chafe on the edge of the tube unless I modify the harness somehow. That's why I'm thinking the sending unit wire must have gone through the tube toward the starter and then backward to the fuel tank.
