Old Today, 02:04 PM   #1
IT Cowboy
IT Cowboy's Avatar
Location: Clarkdale, Arizona in a van down by the river
Timing settings help
I set my timing yesterday at 16 degrees btdc for 3500 ft elevation where I live and unplugged the vacuum advance and plugged the port.
It runs great and I am getting a reading of 35 degrees at 3000 rpm with the vacuum advance unplugged.
With the vacuum on the dist. plugged in at 3000 rpm I am getting a reading of 55 degrees advance.
Is this an issue, am I misreading something or doing it wrong. This is with a harbor freight timing light with the advance dial on it.
The truck runs good now like a streak of **** and will turn over the rear tires. It also stays cool on highway or in town or just idling.
IT Cowboy is offline   Reply With Quote
Old Today, 03:27 PM   #2
MySons68C20
MySons68C20's Avatar
Re: Timing settings help
Your vacuum advance is adding 20 deg of timing in a no load situation..
With 15 initial connect the vac advance and you should see 35 deg on the timing light.
Sounds like it is working correctly.
MySons68C20 is offline   Reply With Quote
Old Today, 05:30 PM   #3
Dead Parrot
2nd the thought it is working properly. 50~55 is the normal expected total light throttle advance.
The higher initial timing normally does cool the idle temps a bit as it is using less fuel to keep running.
Don't worry about exact numbers. There is some variation between balancer timing marks, the mass produced timing cover, the mass produced timing indicator that is spot welded to the timing cover. Yours may be +/- a few degrees compared to the next one.
Dead Parrot is offline   Reply With Quote
