08-03-2022, 07:30 PM | #1 |
Rebuilt Motor, Ticking sound
Fresh rebuilt 350, has a ticking sound pinpointed to where the yellow lines are
got my mechanic stopping by tomorrow doesnt sound like a metal tick, sounds like a plastic ticking anyone have any ideas to check Thanks
A Little Better Every Day Cancer Survivor, most dont know what they have until its gone, appreciate everything |
08-03-2022, 09:43 PM | #2 |
Re: Rebuilt Motor, Ticking sound
Take the breather off the valve cover to see/hear if it gets louder.
08-03-2022, 11:55 PM | #3 |
Most likely it just needs s rocker arm adjustment.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
08-04-2022, 06:42 AM | #4 |
Appreciate the responses
Mechanic stopped by on his way to work pretty much same thought/ lifter loosened up after breakin
08-04-2022, 11:14 AM | #5 |
Good thoughts. Could be from the wear of breaking in or possibly the self locking nut could have lost some of its holding power if it's been on and off a few times.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
08-04-2022, 04:17 PM | #6 |
Make sure the intake crossover passage part of the intake gasket sealed properly or that a couple of intake manifold bolts didn't back out. Easy to forget you have an exhaust flow there.
08-04-2022, 06:59 PM | #7 |
Maybe the distributor cap is off kilter. It's happened to me.
08-06-2022, 05:54 PM | #8 |
Thanks for the replies, always good to have a few ideas
Got the truck to my buddies shop Thursday nite Today got to his shop and he had already checked the rockers, valves, pushrods and cam, lol i had bought a new cap and rotor, took the cap off and the button on bottom of cap was laying on top of the rotor, rotor tip was worn down and cap had burn spots on it got it all back together and no noise, little carb adjustment and she runs great
08-07-2022, 07:28 AM | #9 |
Moderator
Good to hear.
08-07-2022, 01:38 PM | #10 |
At least I'm not the only one who's ruined a cap and rotor. It's nice when the parts are cheaper ones though.
08-17-2022, 10:33 PM | #11 |
Hey
ticking is back, but im pretty sure its the exhaust manifold gasket, using a stick as a sounding tool, if i hold the stick on the motor above the center of the manifold, it sounds good, no noise, if i put the stick on the manifold center, definately a tick Thanks
08-27-2022, 10:17 PM | #12 |
well , went on vacation for a week, dropped truck off at shop, found number 8 lobe on cam is worn, so engine is coming out again, going to check rods and mains, obviously new cam and lifters,
was a Mellings 22107, basically an rv cam i wont go back to same cam anyone have a better or at least different manufacturer couple good things, took filter off , no chunks, only a little silver in oil, so were thinking it just wore Machine shop is working with me on parts ill know more on Monday
08-27-2022, 10:55 PM | #13 |
Bummer, I wish it would have been "cheap and easy". I have a Melling RV cam too. At least the machine shop is working it out with you.
08-30-2022, 02:45 PM | #14 |
Well , some good news , mains and rods are still good. So ordered a new cam. Went with a Howard’s brand only because they offer a 5 year no questions warranty. Paid the difference which I had no problem with. Machine Shop covered all the gaskets and oil and gave me credit towards new cam. So. Hopefully this weekend
Posted via Mobile Device |
09-01-2022, 03:00 AM | #15 | |
09-01-2022, 05:15 PM | #16 |
Moderator
Cam lobes are only splash fed so the new engine, on first fire up MUST be allowed to run at around 1800 to 2000 rpm for at least ten minutes.....
It must be full of oil, water and have all belts etc in place....do not allow the new engine to idle. Are you assembling the engine? If you are you must use a good quality cam lobe lube on both the lobes and the bottom of the lifters. The oil in your engine MUST contain a high level of Zinc to prevent cam lobe destruction....modern oils do not contain Zinc as it pollutes the catalytic convertors on later model cars. As the engine had silver traces through it I assume its been hot tanked with all the gallery plugs removed? Let us know how you go.....
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
09-01-2022, 06:19 PM | #17 |
Maybe you can talk the machine shop into throwing a roller cam in her and never worry about the correct ZDDP or break in periods.
Hope everything goes well. |
09-04-2022, 01:09 PM | #18 |
Maybe too late now, but make sure the machine shop runs a hone through the lifter bores. Every now and then the bores get a little tight and do not allow the lifter to spin properly
09-07-2022, 09:59 PM | #19 |
Hey
yes the motor has been gone through again, everything is still good, got her back together and hopefully firing up tomorrow, yes to zinc additive and am using Valvoline VR1, yes to running at least 20 minutes on breakin at 2000 rpm, hopefully this one does good, if not ive got the 5.7 vortec on the stand lol Thanks for the ideas and suggestions
09-09-2022, 05:40 PM | #20 |
well, another bad update
6 minutes into breakin, #4 exhaust lobe wore already talked to Haward;s and im probably going to go roller upgrade not a happy camper
09-09-2022, 06:20 PM | #21 |
Did you have the motor hot tanked?
09-09-2022, 09:40 PM | #22 |
Moderator
What oil were you using during break in?
Have you checked the valve spring installed pressure and checked for coil bind? I assume you used new lifters on the new camshaft. Was the block hot tanked and pressure cleaned out including the oil galleries with the gallery plugs removed? Moving to a roller cam may still fail if these essential steps are skipped....
09-11-2022, 02:30 PM | #23 |
ticking is a collapsed lifter
yes to all questions about having block checked still going with roller cam and lifters this time call Howards tomorrow and see what they will cover Parts wise
09-11-2022, 05:00 PM | #24 |
Moderator
Collapsed lifter from new? Nice....leaves a sour taste in your mouth.
Go the roller cam and lifter route.... I usually build Vortec SBC now, its been at least a year since I built a flat cam engine.... Good luck....make sure the kit you buy has the anti rotation pieces for the rollers.
09-11-2022, 08:32 PM | #25 |
I wonder if everybody is just making junk parts now or what. Almost everything I drive is flat tappet engines but they were all assembled over 5 years ago. The last cam I bought was the Summit $100 special and still working like a champ.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
