Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 04-11-2022, 09:45 PM   #1
Baketown Scotty
Junior Member
Baketown Scotty's Avatar
Engine Removal ?
I need to remove the 350 from my 1966 GMC 4x4 Suburban. Would it be easier to unbolt from bell housing and clutch then remove engine only? The transmission is NP540.
1964 Chevy Suburban 4x4
1966 GMC Suburban 4x4
Baketown Scotty is offline   Reply With Quote
Old 04-12-2022, 12:11 AM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Engine Removal ?
I haven't pulled an engine from a 4x4, but I unbolted my 283 at the bellhousing and lifted it up and out. I left the flywheel and clutch assembly attached to the engine when I pulled it. Also put it back together that way.
Definitely helped having the hood off. I used the engine hoist to pull and reinstall the hood too
Throw a jack or two under the transmission for good measure though
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 04-17-2022, 11:11 AM   #3
Baketown Scotty
Junior Member
Thank you. I'll go that route.
Old 07-07-2022, 03:39 PM   #4
Baketown Scotty
Junior Member
Did it that way and went well. Did not have to remove the hood but it was real close. Also removed the NP540 separately. Going to try and replace seals to stop all the leaks if I can find the parts.
