Old 02-22-2023, 05:25 PM   #1
6600DURAMAX
6600DURAMAX's Avatar
LS3 water neck and radiator hose
Want to make sure this water neck will fit on the BOTTOM outlet on my LS3
Also - any suggestions for the upper and lower radiator hoses ?
1972 K5 Build - plans - LS3-6L80e-One Tons.....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 02-22-2023, 05:53 PM   #2
LS short box
Re: LS3 water neck and radiator hose
I don't know about the thermostat housing but in regards to the radiator hoses I make a wire pattern and then hit the parts stores. Most will let you look thru them to find what you need.
Just a note. The earlier LS engines had a "fixed" thermostat in the housing. The later LS housings have removeable thermostats.
Old 02-22-2023, 06:27 PM   #3
Joyridin
That listing shows 1997 - 2020 LS engines, but they changed the thermostat design in 2014 or so. Maybe they made the new ones universal? I had to mill open the diameter where the thermostat sits about .050" on the diameter to get the earlier version to work with the later thermostat.
Joyridin is offline   Reply With Quote
Old 02-22-2023, 09:12 PM   #4
6600DURAMAX
Does the thermostat typically go into the lower hose or the upper ?
Old 02-22-2023, 10:17 PM   #5
LS short box
Always in the lower on LS engines. See pic of my 68 C10 LS swap.
SBC had the stat in the upper hose.
Old 02-23-2023, 06:13 PM   #6
kglowacky
impressed you got the coil installed without the spindle on.
kglowacky is offline   Reply With Quote
Old 02-23-2023, 09:54 PM   #7
LS short box
Good thing about lowering springs that it makes it so much easier to install the spring and then the spindle.
Old 03-16-2023, 09:48 AM   #8
6600DURAMAX
Back to the top
Thermostat housing is on now just to find the upper and lower hoses
I have searched a few times - seems most suggest the Upper hose to be a Gates 21439 but that has the water neck that comes up and out at like a 40 degree angle, my LS3 has it coming out totally different.
I also couldn't find a clear answer on if the lower hose Gates 21439 had the correct end sizes ?
Neither of the autoparts stores had them in stock or I would have tried
Old 03-16-2023, 01:37 PM   #9
mongocanfly
mongocanfly's Avatar
I've had to splice pieces of hoses on some of the ones I've done..so that could be a option
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-16-2023, 06:14 PM   #10
Joyridin
I replaced the lower outlet with a straight version. It was on my car, but it works well.
Old 03-16-2023, 07:09 PM   #11
6600DURAMAX
I think the lower hose will work, ordered a GAtes 20931.... be here next week
Old 03-19-2023, 01:28 PM   #12
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Yes that thermostat housing will work. I used the same one on my LS3. I would also use Mr. Gasket Thermostat, PN 6368.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
