03-20-2022, 04:44 PM | #1 |
Junior Member
Hello From Tejas 55.1 GMC 100
Hello All,
New guy here. I currently have a 55.1 GMC 100 1/2 ton 5 window custom cab short bed that has been following me around since 1977. I purchased the truck in Lubbock Texas, drove it for 3 yrs and then tore it down to " Hot Rod" it. At the time I had installed a mildly cammed 4 bolt main 350 and turbo 400 tranny. Moved to the Dallas Fort Worth area when life got in the way of the truck until mid to late 90's when I bolted on a 76 front suspension from a GMC 1/2 ton and swapped out the rear end. Again life crept in and the project stalled. Retired in 2017 after 40 yrs and last year I finally realized what direction I wanted to take the truck at this stage in my life. Which brings me here. My current plan is I am going to install a Flat Out Engineering C4 Corvette suspension and swap the 350/turbo 400 for a LS 6.0 and have not decided on the tranny yet. I have sourced a dana 44 C4 IRS and a C4 IFS both 84-87 yrs. Well thats my introduction, look forward to your thoughts and idea's! |
03-20-2022, 09:23 PM | #2 |
Re: Hello From Tejas 55.1 GMC 100
Welcome! Sounds like it will be fun to carve some corners
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
03-20-2022, 10:08 PM | #3 |
Moderator
Welcome to the forum.
03-22-2022, 12:20 PM | #4 |
Welcome, Please start a build thread, with lots of photos, in the 47-59 build forum.
03-25-2022, 10:11 AM | #5 |
Welcome! That sounds like quite a project. Congratulations for holding on to your truck through thick and thin.
