01-09-2012, 12:17 AM | #1 |
72 c10 speaker ideas
so eventually I am relocating in cab fuel tank to rear but until then were are some good spots for speakers... I have room under the seat for an amp and maybe small speakers but were else.... door, side panels...were else.. post pic if you have them
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
01-09-2012, 12:24 PM | #2 |
Re: 72 c10 speaker ideas
I have 6.5" mids in custom kick panels, 3.5" highs in the center dash, 1" tweet in the door, 6.5" mids in the upper corner of the rear and 2 10" subs + 2 amps behind the seats. I made custom pods for the door tweets, I didn't want to cut the bottom of my doors. Most of my stuff will be well hidden unless you know what you are looking for. Ton of pics in my build thread.
I personally don't like to put amps under seats. Poor venting and usually limited clearance.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
01-09-2012, 01:18 PM | #3 |
thanks, I will look at your build
01-09-2012, 01:26 PM | #4 |
67-72 parts collector,…
Look at these:
http://67-72chevytrucks.com/vboard/s...speaker+mounts
01-09-2012, 01:39 PM | #5 |
nice and will definatley keep those in mind when i relocated the fuel tank but want ideas for location for speakers and such with the tank in the cab.... and I don't mind cutting into the bottom of the door either.....
01-09-2012, 05:12 PM | #6 |
after looking at it, think the amp will mount passenger side behind seat were jack was and one 6x9.... then some door speakers and a small sub box in front of seat tucked half under the seat since seat will never be pulled forward..... like 6 1/2 subs or 8's... think it will sound good enough for a young kids that is 16 soon...... cause I am thinking it will be a few months before we tackle moving the tank to the rear out of the cab
01-09-2012, 07:26 PM | #7 |
needs more $$$
If you can't put 2 6x9's (one on each side) back there, do don't it...it would be off balanced.
2 fairly decent speakers in the door with an amp will be fine. I feel custom kicks are the best route, but I'm no purist so cutting the doors is actually the easiest. I know it's possible to fit a 10" sub under the bench...my neighbor's cousin has a 67 with a 10" sub under the bench. It sounds really nice too. The sub is under the passenger side and the amp is under the driver. I've mounted most of my amps underneath the seats of my rides. Not ideal, but if you're not overloading the amp, it's fine.
1970 2wd Blazer |
01-09-2012, 10:23 PM | #8 | |
